Low Latency computer for Merging NADAC
Hoosr1
12
6
8
62
My 15 year old computer finally died. I am using the original Merging NADAC and the ethernet connection with JRiver. Any recommendations on a low latency computer? It will be only used in the audio room and for no other purpose.
Thanks,
Tom
Reactions: Piet de Vries
Thanks,
Tom
Do you want it in the footprint of your old computer case volume? (Not necessarily in the same case but a cafe of similar volume)
You can build yours. I can send a part picker link to a build that priorities read, write speeds, superb LAN speeds and pretty awesome idling and thermal load efficiency
