Thanks. Nice set up!Not much to show, but…..
I was able to (easily) play a bit with the angle of each sub. First few cuts played show promising improvements.
I have to give you credit for being late to the party but you finally arrived LOL. Try using a EVP or a serious quality footer , like the Carbide's, under the subs and you will get some real improvements. I am not a spike guy and with all the interesting devices that one can use under speakers and especially subs there are a lot of room for improvement in doing such.Jim Smith came over Saturday and we tried something entirely new which was raising the subwoofer up off the floor to align vertically (driver domes) with the lower woofer on my main system. The point is to get the woofers "working together."
Honestly, I was very skeptical and wasn't sure I wanted to lift the heavy subs. Fortunately I had two solid wood amp stands that lifted 4" exactly and worked sonically, if not quite aesthetically. I can eventually get one of the HRS platforms to work I believe and in black it would match the speaker hardware.
We also found that moving the subs (which are on the outside of the mains) closer to the mains paid dividends in sound quality.
The results are quite spectacular. Much more smoothness in the bass and the spatial cues are even better. I am super happy with the results.
(...) The results are quite spectacular. Much more smoothness in the bass and the spatial cues are even better. I am super happy with the results.
Mine alsoMy subs are on the ground, but stand 7 feet tall.![]()
These results are due to increased height or the woofer, leveling with Alexia woofer, or to the decoupling of the sub from the floor?
We believe leveling with the Alexia V woofer allows them to work together.
The problem is that considering the involved wavelengths they always work together. An interesting experiment would be raising them an extra 4".![]()
