Looking For Class D Candidates
To which tube amps have you compared them directly in your own system?
It's been a long time since I had a tube amp. The last was Shindo Sinhonia push pull f2a monoblock amps. So no valid comparisons.
Reactions: Ron Resnick
Any decades-long tube amplifier manufacturer who is so determined to torpedo his own tube amplifier business by dissing tubes in favor of his Class D amps must be onto something.
This is quite an offensive over-reach. You can recommend the Class D based only on a couple hours of listening but there's no need to, imo, mischaracterize Atma-Sphere. The company continues to sell and support its full line of tube amplifier and preamplifiers. From my discussions with Ralph he never suggested he was out to "torpedo" his own designs. His OTL and OCL products continue to provide top quality sound. Class D is an expansion of his product line.
His stated rational for building the Class D amps is a belief that tubes will continue to be less frequently adopted and thus become less available. That view, so he explained, comes not from the audio world but from performing musicians who use electronic amplifiers to make their music (eg. Fender, Marshall, Mesa/Boogie, etc.) That group uses far more tubes than the audio world. So, as I said, he is forward thinking. "Tube amplifiers are on borrowed time." We'll see if that turns out to be true, but it is not a "diss" or an admonition to stop using tubes.
Imo, the rationale for Class D when compared to tube amplifiers is not superior sound quality. "Foremost in rationale may be Class D's higher efficiency of operation—it uses considerably less energy than Class A or even Class A/B. Because of its efficiency it produces less heat and does not require the massive heat sinks found on less efficient amps. It does not require big transformers and capacitors. That means you can fit one in a much smaller and lighter package." They are also less expensive to build which appeals to those looking for lower entry price to an audio system.
In his defence; I think it was an attempt at humour.
strange -- no one was laughing
There are not a lot of laughing scenes in that movie.
I suppose sometimes it can be hard to know when it is funny without a laugh track to queue us… ;)
If it was intended as humour, then maybe he should have put in a ;) to help convey it?
I think anyone interested in a Class D amplifier should start with Ralph's Atma-Sphere Class D amps. Any decades-long tube amplifier manufacturer who is so determined to torpedo his own tube amplifier business by dissing tubes in favor of his Class D amps must be onto something.
I don't think Ralph is torpedoing his tube amp business, but he's more likely trying to stay in business! Tube stuff is on the decline because of its high initial cost, high running costs and a sound that can now be matched or bettered by the best Class D technology - at much lower cost. Other tube brands will struggle to survive if the doggedly ignore Class D.
I have Ralph's Class D monos and a Purifi Eigentakt amp. The latter technology is currently the best mainstream Class D, but there are dozens of amps built cheaply using the Purifi Eval(uation) board that is offered at low cost to DIY builders. Best not go that route, but look at the big brands (NAD, T+A, etc) that build under license with superior components and use carefully designed and matched ancillary parts such as power supplies.
I am still undecided whether I prefer the Atma-Sphere over the NAD Master Series that uses Purifi. Both are extremely good amplifiers. The NAD was chosen after a year of home evaluation with numerous amps in the £3-8K range of Class A, AB and D. All were bought or borrowed after I decided to move away from SETs, but only if I could find an ss amp that would match or better the listening enjoyment level of the SETs
Thank you for your critique. I am a huge fan of Ralph personally and of his tube electronics.
I edited my original post to distinguish between Ralph's OTL amplifier business and the SET designs he rails against. It was my unintentionally offensive mistake to have failed to make that critical distinction in the first place.
In December of last year I wrote to Ralph:
1) Respectfully, as a manufacturer of tube electronics your position that you don't like SETs is detrimental to your business model. It is not good for you to be a proselytizer against SET. This should not be your focus.
2) Focus on showing why OTL is great, not why SET is bad.
How old were you when you had your humorectomy?*
*I know that a humorectomy is not an actual surgical procedure.
I fully agree on both points. It was exactly on these points that I encouraged Ralph numerous times over e-mail and telephone to respond crisply to Mike Gefteas' original (graciously later corrected) suggestion last December that Ralph had stopped making tube amps.
Reactions: tima
This may come as a shock to some -- it certainly came as a shock to me -- but I am prepared to recommend a Class D amplifier. I listened over the weekend for several hours to Laiv Class D GanFET amps. These things are $5,400 a pair, about the size of a container of Pepperidge Farm cookies and weigh only a few pounds.
Don and I went to Jim Yager's house. Jim has the giant PBN M777 loudspeakers, ARC REF 10 line stage and Soul Note phono/optical, Acoustic Signature Montana turntable and DS Audio optical cartridge.
Jim feels and Don feels that these tiny Class D amps are the best amplifiers Jim has had in his system, beating vintage Mark Levinson, ARC amps, Jadis JA30s, Luxman, Canary and Lamm hybrids.:oops:
I am reserving my judgment until I get a direct comparison with the Lamm hybrids, which heretofore are my favorites in Jim's system. But I agree with them that these cheap, tiny amps sound inexplicably good.
That will be a cool thing to read about as you get more time listening!
Ralf has stated many times that his Class D measures better and sounds better than his tube amps, sometimes in this forum. I don't think that is torpedoing his designs, there are those that will just continue to like the distortion profile that tubes provide, compared to the (smaller in measurements) distortion profile of his Class D. He has also stated that the distortion artifacts left in his Class D tend to be 2nd order and lower level harmonics, much like tubes. I am not dissing tubes in any way here, we have to accept some distortion in an amp, we just choose the profile that to our ears lets more of the music through.
I do have quite a bit of personal experience with really good sounding power amp design by now. That said, of the several things that generally kind of hold class D back is, many designs use a generic (more or less) SMPS PSU. I really wish that was sufficient to get the best audio results, but unfortunately the audible reality is that it simply isn't. If it was, believe me we'd all be using it as it has a lot of other very significant advantages. To the lynch mob who want to rail about the above statements, my only response is, please first try it for yourself and find out. In your favorite amplifier deign try both an audio SMPS and a good linear PSU, then report back and share your own findings.
Our class D amps use linear power supplies.
I feel a need to clarify this a bit.
I heard a class D amp at AXPONA about 8 years ago that I felt was operating in a territory that previously was only the pervue of tube amplifiers. On that account I came to the conclusion that if we didn't get a handle on class D we'd get left behind.
Our goal was to build a class D amp that sounded as good or better than our OTLs. Since OTLs are some of the most transparent/revealing tube amps ever made this might have seemed like a big ask. On top of that the amp had to have the smooth character you expect of an excellent tube amplifier- no harshness.
We felt it would send the wrong message to the marketplace if we fell short of those goals. But when the amps were finally ready we had surpassed them- the class Ds are relaxed and we get high consistency when people compare to tube amps (as we have) in that the class D is more 'focused' so its easier to tell what's happening in the rear of the sound stage; IOW more transparent/resolving.
But because the amps are not bright some will say they lack 'sparkle' (which is a term I really dislike). IME 'sparkle' is a brightness brought on by higher ordered harmonic distortion- such amps tend to get harsh at higher volumes. The bandwidth we're getting is well past what anyone can hear. So tonality on the top is not a function of frequency response. Its coming from a lack of unmasked higher ordered harmonics.
I did not set out to kill our tube amp business (recently our MA-2 OTL has been selling quite well; mostly to the ESL loudspeaker market). I like tubes- they are fun and have a kind of gothic nature to them not unlike prewar motorbikes. We just introduced a little 5 Watt integrated amp recently that IMO easily takes on SETs of similar power. And I'm working on other tube amp designs too. But I've no illusions; its just for fun, since when it comes down to it the class Ds are consistently more musical.
Getting a class D amp to sound like an excellent tube amp is allowing them to invade the musical instrument market. I've been watching that happening for the last 15 years. Many guitar players rely more on their effects pedals for their 'sound' than they do the amps, which is quite different from 20 or 40 years ago. They still avoid solid state because they can be to shrill or biting. But if the guitar amp is relaxed like tube guitar amps are, it will be a big change because a Fender Twin weighs about 70-80 pounds while a class D guitar amp head of the same power might be only 15 pounds. That's a huge deal if you can get the sound you want as well. At 3:AM when you're done with a gig you notice things like that when moving out of the venue.
The musical instrument market sales of vacuum tubes is 10-20x larger than the entirety of high end audio. If class D makes a serious encroachment into that market its going to hurt tube suppliers. That, and the fact that we can build class D amps that sound better than tubes is why I think tube amps are on borrowed time.
Reactions: Argonaut
My Canor A1 2.10, we have the well-known Hypex power unit in Class D powered by a filtered and tuned linear power supply. It is a great sounding hybrid integrated that is on par with my Qualiton X200.
Reactions: Atmasphere
But because the amps are not bright some will say they lack 'sparkle' (which is a term I really dislike). IME 'sparkle' is a brightness brought on by higher ordered harmonic distortion- such amps tend to get harsh at higher volumes. The bandwidth we're getting is well past what anyone can hear. So tonality on the top is not a function of frequency response. It’s coming from a lack of unmasked higher ordered harmonics.
Yeah Ralph… ^100%^
“Sparkle” is probably a silver lining way to describe a problem so that it sounds like a benefit.
“Resolving” might also have a cousin the fight here.
When people get used to ^that^, then if they miss it, it at least is saying that they can hear a difference.
Hence it could be important to some that they understand that your amp might sound quieter than an amp with an abundance of the higher order harmonics.
While to me that is indicative of a system that is getting really good, to others they just may want more of a “wall of sound” and the extra shrillness.
In the extreme they might call a low distortion amplifier “dull”.
While I can see where they are try to come from, it is IMHO more appropriately worded as “non-fatiguing.”
And I have seen a fair number of the low distortion amps also described as unmusical.
I doubt that music is mixed in such a way as to account for high distortion amplifiers, but there is a circle of confusion that makes it hard.
And a lot of people just like lots of distortion.
@Mister Pig has at least been given some idea of how it may sound.
I have heard some people talk about a lack of sparkle with the amps.
And inside of the review in post #2, it somewhat hints at that.
Just as people have different perspectives on pieces of music, I sense that they attach different meanings or associations to different words. That's okay up to a point. As far as my intent in writing that review, I was pretty clear on not hearing brightness. I had no thoughts of 'sparkle' ... and I try not to hint. ;)
I am mostly agnostic on "sparkle". I think I've used the word twice in 20 years of reviewing. In both instances I was describing a difference between ohm taps once on a a amplifier and once on an autoformer. "... a silvery frosting on higher frequencies from violins and brass ... it was more like catching a sparkle out of the corner of my eye."
Perhaps you can derive it from "bright" although that is not found as a synonym. Literally "to throw out sparks." There are other meanings/definitions of the word -- for example, 'sparkling conversation' sugests liveliness or vivacity, both good music description words, imo. An antonym might be "dullness". My tendency is to describe what I hear from music with a review component in system, rather than trying to attribute a physical cause.
Sparkle is a word I've used occasionally and probably I should avoid it. I've used it when trying to describe the feeling that induces goosebumps or similar reactions to music that particularly excites one. Some amps are drearily dull (perhaps another word best avoided) where one is inclined to turn down the volume. Others excite the senses, and one is inclined to turn up the volume and wallow in the experience. Speakers are a bigger contributor to this phenomenon than amps, but a suitable amp is also needed to create the effect. The wrong amp will make one wonder why you've spent so much cash on those wonderful speakers you were expecting "live performance" results from. A well matched amp will justify the speaker choice.
Thanks @tima for taking the time to respond.
Well here is what was written.., in the review section titled “sound” from the PF article:
To pick nits, when I reviewed my listening notes I found a consistent mention of slightly diminished leading edge articulation. Call it the difference between a more incisive attack (not to be confused with harshness) and a softer attack, but not rolled off—pizzicato strings still sound pizzicato. This softer attack can sometimes smooth out a sense of texture across an orchestra or group with multiple voices playing concurrently and it can (not always) lessen the sense of the first bite of string on bow, tongue on reed or pick on guitar.
While you may not have hinted at sparkle (or in the is case a specific lack thereof)… I read it as possibly a lack of higher order harmonics that made the attack seem softer.
And the next paragraph from the review:
The amp's warmth is dry warmth, not slushy or wet warmth. While they play romantic music quite nicely, these are not romantic sounding amplifiers. Depending on the music, there is a nice sense of flow across notes although it is not quite as liquid as certain tube amplifiers I've heard.
^this paragraph^ doesn’t at all hint to me about sparkle… but the “dry warmth” does, or may, resonate with @Mister Pig in terms of a quieter sounding amplifier.
^100%^ in agreement.
However… I have heard others use sparkle, and lack of sparkle, enough to raise it as a potential issue if the OP is “hooked on sparkle”.
If the OP was hooked on “dry warmth”, then it being a pleasurable choice could more of a certainty.
I own the LAiV GaNM monoblocs and I must say that I'm impressed with their performance so far. I'm using them presently with my 98db single driver speakers (I know... Overkill with power), however they are dead quiet, micro and macro dynamic and sonically are terrific. I see no downside to these GaNM's compared to my Accuphase A48 class-A amplifier. They are compact, well-built and the support from LAiV is second to none. The real test will be when I soon get my Final Model M12+ electrostatic speakers which are notably less efficient and present a more considerable load. However I actually believe they will work very well with the GaNM's.
