If I remember correctly it was:
1. Tango
2. Tamura
3. James
4. Trafo Baule
5. Lundahl
6. Gerd Reinhöfer
7. Thöress
1. Tango
2. Tamura
3. James
4. Trafo Baule
5. Lundahl
6. Gerd Reinhöfer
7. Thöress
Hi Rolf,If I remember correctly it was:
1. Tango
2. Tamura
3. James
4. Trafo Baule
5. Lundahl
6. Gerd Reinhöfer
7. Thöress
Ach kiek ma der Rolf aus München ...ServusYes, Thomas and me started this project for Roehren & Hoeren back in that days. The picture was taken at one of the shootouts with several variants of the schematic and some variants of compoents used. We tested e.g. output transformers from James, Tango, Lundahl, Gerd Reinhöfer, Thöress and others but also combinations of the driver stage with different power tubes (6CB5A, 12E1, 300B, 45).
We had two Tango transformers in the race, one made it to number one position and the other was among the worst sounding.
Yes the U 808 is usually the worst rated. Thanks for the model mentionsISO Tango, if I remember correctly, models XE-20s and U-808 whith the XE-20s rated first, the U-808 worst. James was the model JS-6123S
I don't think you can say that in general. For the U-808, it was probably the wrong application – as an output transformer for a tweeter amplifier in an active multi-way setup, the result would probably be different.Yes the U 808 is usually the worst rated. Thanks for the model mentions
If your speaker is efficient enough, or if you listen low enough, the 2a3 is an amazing sounding power tube, in my mind far better than the 300b. The mids are richer and the bass is fuller. Why this is I cannot say but the 2a3 amps I have heard bested anything single ended, save a Komuro 845 I heard once and only once at a builders show at a warehouse. Many swear by the AN Neiro which use two of the tube in parallel fed by an IT, and claim it to be the best of their offerings.Why do so many people use 2A3 or 300B. My amp also has a lot of Monolith iron. Its a KT PP amp. I asked about a 300B or 2A3. I was told they are good tubes, but an 811 can be an even better tube.
Actually you're describing how much better the output transformer works when you don't have to make as much power.If your speaker is efficient enough, or if you listen low enough, the 2a3 is an amazing sounding power tube, in my mind far better than the 300b. The mids are richer and the bass is fuller. Why this is I cannot say
Is that a function of current, voltage or a combination of the two? I’ve heard good sounding high voltage set’s but each had an enormous output transformer and likely used a current figure similar to the 2a3.Actually you're describing how much better the output transformer works when you don't have to make as much power.
The more power you have to make with an SET, the less of the 'magic' of SETs. This is why the type 10 and type 45 power tubes are considered more highly than the 2A3. It has little to do with the characteristics of the tube and a lot to do with how the output transformer performs.
It has to do with the DC magnetic field caused by the current of the power tube being drawn through the primary winding of the transformer. This induces a DC magnetic field and is a function of current. To get around this problem there is a saw cut in the core of the transformer which vastly reduces the DC saturation issue. The less current the less DC saturation; the gap thus made has to be larger when more current is present. That gap also affects low frequency bandwidth!Is that a function of current, voltage or a combination of the two? I’ve heard good sounding high voltage set’s but each had an enormous output transformer and likely used a current figure similar to the 2a3.
My favorite SET at home with my Klipsch La Scalas is the Oliver Sayes' designed 421a. The Western Electric 421a is just a miracle tube, which I like far more than the 300B or the 45 (both of which I have as SET amps as well). One power tube for both channels simplifies the design of the SET even more. The 421a has a bit more power than the 45, about 3-4 watts. It's just got that magical midrange to it, and no one did it better than WE. You can also use the Tung Sol 5998, but that doesn't sound quite as magical in my opinion.If your speaker is efficient enough, or if you listen low enough, the 2a3 is an amazing sounding power tube, in my mind far better than the 300b. The mids are richer and the bass is fuller. Why this is I cannot say but the 2a3 amps I have heard bested anything single ended, save a Komuro 845 I heard once and only once at a builders show at a warehouse. Many swear by the AN Neiro which use two of the tube in parallel fed by an IT, and claim it to be the best of their offerings.
Is it direct coupled?My favorite SET at home with my Klipsch La Scalas is the Oliver Sayes' designed 421a. The Western Electric 421a is just a miracle tube,
The 421a has specs similar to the 6AS7G but with greater mu. A single one of those tubes is good for 10Watts in class A with the right load if you have it wired in push-pull (its a dual triode so this is possible).My favorite SET at home with my Klipsch La Scalas is the Oliver Sayes' designed 421a. The Western Electric 421a is just a miracle tube, which I like far more than the 300B or the 45 (both of which I have as SET amps as well). One power tube for both channels simplifies the design of the SET even more. The 421a has a bit more power than the 45, about 3-4 watts. It's just got that magical midrange to it, and no one did it better than WE. You can also use the Tung Sol 5998, but that doesn't sound quite as magical in my opinion.
The 421a is the sleeper tube of the century. You can still buy NOS versions without paying a king's ransom (unlike the NOS WE 300Bs).
There's a reason why direct heated triodes are also a bit noisier than the 421a, but I'll leave that discussion to the folks who build SETs. There are a few others who design 421a amplifiers as well, and these show up on AudioMart from time to time.
Glow in the Dark Audio - Oliver Sayes Western Electric 421a
Glow in the Dark Audio showcases Kevin Davis’ personal collection of small-scale, DIY and one of a kind hifi audio gear, with a focus on single ended and push pull tube amplifiers and full range open baffle speakers.glowinthedarkaudio.com
Altec 604- 8g driver in a onken bass housing.What would you recommend for a 99db 8ohm speaker? (which is horn loaded with a dynamic large driver)
Listening position is -8ft (2.5m).
Thanks, however my question was about asking for SET amplification recommendations for a speaker(s) with these specifications.Altec 604- 8g driver in a onken bass housing.
Or this one in topquality ,careful 100kg each speaker
Altec Lansing 604E Duplex
Ein Paar Altec 604 Duplex. Die Gehäuse sind vom Tischler nach genauen Altec Plänen gebaut Worden....,Altec Lansing 604E Duplex in Niedersachsen - Barsinghausenwww.kleinanzeigen.de
Full Kondo is out of reach. Also, from what I understand, the Kagura and the Ongaku are the recommended amplifiers in the current line, and they are way above budget and an overkill for 99dB speakers. I don’t know how their 2a3 based amp is.You could use any low watt set amp off your choice. There are many. You could go full Kondo, though you don’t have to. Or full Mayer with his 300b, or various other smaller manufacturers. 300b, GM70 if well done
