Motor noise only at 100 ohm impedance
Narrowfellow
6
54
San Jose, California
I'm wondering if anyone has encountered anything like this. I'm running an Audio Technica AT33MONO cartridge on what's essentially a Rega RB300 tonearm, into a PS Audio Stellar phono preamp and then into my Leben CS300F. A wonderful feature of the PS Audio is that you can change the loading via remote. While listening to different settings, I've discovered that I get fairly loud motor noise when using the 100ohm setting. All other settings are dead silent. I just recently started using this table/arm combo with the Stellar so I don't have any other cartridges to compare, but when on the SME table with Koetsu, Benz, or Sumiko carts, no problems at all. Just a weird combo, or?
This sounds very strange. Are you certain the noise is caused by the motor or is it just humm? How does a stereo cart behave? It should relay more motor rumble.
Does the noise disappear when the motor is stopped?
As far as I remember the Rega RB300 does not have a separate ground wire - the arm is grounded using the left channel ground wire. If you use a mono cartridge you are probably creating a ground loop somewhere with maximum current with a low load resistance.
Reactions: analogsa
The table is a Linn LP12 with an Origin Live DC motor in it. Might be a grounding issue as @microstrip mentioned, but the tonearm is rewired with a ground wire. Noise only comes out of the left speaker and only when the phono preamp loading is set at 100ohm. Not a big deal because I prefer the sound at 200ohms anyways -- but still an odd, subtle, quirk. Thanks for chiming in guys.
Ok, maybe you are getting a ground loop because you have a double earth path - do you still get this noise if you disconnect the ground wire?
Reactions: mtemur
