Lampizator Genya
Gentlemen, I am really thrilled by the fact that your impressions are mostly positive. I had to force this design upon our company, because it was not in line with the lineage, not in line with the price pyramid, not consistent visually and generally noone wanted it from the inside of the factory.
It could have been my spectalular flop personally but fortunately it is the opposite.
We started selling the PLUS version but the sonic difference is very small, I really like the base model. The PLUS has maybe a touch more defined and more controlled deeper bass. Which addresses the minor compaints above in this thread. We also have a 6N6P to ECC182 adapters so the changeover can be very quick. Tall chassis allows for the adapters and tall triodes. We just secured 10 more boards from Horizon engine upgrades so this will keep us working till the late end of summer.
Had I not purchased the Poseidon in early 2024 and I already had my Westminster Labs Quest 2 pre-amp (which I purchased this year), the Genya Plus would probably been my choice. It is more compact and fits into a rack shelf. Plus, I heard my system with the Horizon first and found the dynamic contrasts out of this world.
What I found out though is that the OEM tubes in my Poseidon are perfectly adequate as a DAC feeding my Quest 2. I hear greater separation, richer tone, trailing off sounds, etc. compared to the Poseidon used as a DAC and pre-amp; but, at twice the price with the Quest 2. I still use the Poseidon pre-amp inputs as a supplement doing double duty, to my Quest 2 for my 78 rpm turntable/post it's pre-amp and cassette deck while the extra Quest 2 inputs for R2R and DAT deck. The sound pass-through sounds sonically identical to direct feeding the Quest 2 using XLR output from the Poseidon (Westminster Labs Ultra XLR).
P.S. I don't stream and use the DAC for CDs only (16,100 currently), pending use for with a music server for thumb drives and hard drives.
Sublime, and Surreal
The Genya is my 7th LampizatOr DAC. From 2014 to 2021 I had a Big 5, Big 7, and then the Golden Atlantic TRP. In 2021 I moved to a Tiny House, and then to a boat, so sold my entire system. In that interim I had the Amber DAC/Amp, and then the Fezz Equinox (this is a damn good DAC for the money). Recently I moved back to a house, and am rebuilding a system. I picked up where I left off with the Atlantic TRP. A month later the Genya was announced so I jumped on board.
For reference I’ve also owned many Linn DAC/preamps (prior to 2014), a Meridian, 3 different Wavelength DACs, and the Chord Hugo TT2. And for reference, the Big 7 as it was, to my ears, is better than all of these. I also considered the Atlantic an endgame components – one I would been happy to own and listen to to the end of time. Even with that I was intrigued by the Genya and knowing what Lukasz could build.
I feel like I’m pretty familiar with the LampizatOr ‘sound’ and what to expect from a LampizatOr DAC (or so I thought), which is why it was a no-brainer to come back to the Atlantic when rebuilding a system.
The Genya though is something different entirely. I don’t know if it’s the particular tube, the no frills design, or the Horizon engine, but the sound doesn’t fit with the other LampizatOr DACs I’ve heard. For me, I’m still listening going back and forth between the critical listening and uncovering what’s different and what’s there, and just the pure enjoyment of listening for the sake of listening.
The primary characteristics I would say is sublime. That says everything and nothing. Honestly though it’s hard to describe. At the beginning I added surreal – again everything and nothing – I’ve never heard anything like this.
Does it have all the good sound stuff – soundstage, depth, breadth, clarity, smoothness – absolutely! It is better than the Atlantic – absolutely. A couple others have said it may lack some bass – I can see that – and I’m fortunate to have both volume and crossover knobs on my speakers for bass, so I’m spared any lacking in that area. I did have to turn up the volume a few notches compared to the Atlantic though. Someone also said it seemed to have a more natural decay off notes, and I would agree with that. It seems to do well, as every LampizatOr I’ve heard, with almost any music or style. Brass and horns, women’s voices, piano is particularly good, hard-core rock, blues, and so on. I’ve had it burning in for about 200 hours now, it took at least 100 hours before it started to open up and sing.
I don’t listen to classical or symphonic music much, still I played some to discover more in the Genya. After listening to a few tracks, I am inclined to explore this part of my collection more. Each instrument – brass, woodwinds, strings, harpsichord, percussion – had a beautiful sound and intonation clearly distinct from all the others.
I played my favorites tracks – tracks I’ve played for decades – Chris Rea, Sarah McLachlan, The Wailin’ Jennys, Traveling Wilburys, Mark Knopfler, Blues Brothers, Ebba Forsberg, Jesse Cooke, and others. Perhaps it was lacking a stereo for over 3 years, but every song is even more of a joy to listen to. There have even been a few moments that I would call a double-take – I’m a bit stunned at the sound and what I’m hearing that I just freeze and listen deeper.
While I miss the glow of the tubes, and that box takes up a lot of space – the Genya is an stunning DAC. I have a new endgame component!
The rest of my system – Don Sachs Valhalla pre-amp/amp, Eversolo DMP-A8 streamer, Vaughn Zinfandel speakers with built-in subwoofer in each speaker. Speaker cables are Linn; VooDoo power cables for the speakers; IsoTek power bar; and the rest is Sablon – USB, interconnects, and 3 power cables.
Nice review. Curious about this model, as would be my first Lampi. Am a bit concerned about "lack of bass" though.....
I would encourage you to listen for yourself and come to your own conclusions. I auditioned the Genya in my room and it was exceptional. Every room has its own idiosyncrasies and every listener has their own biases.
There is a saying, "one man's ceiling is another man's floor." Only you know which floor you live on.
I totally agree. There isn't a way to home audition these in the states is there?
My Genya arrived today and it's glorious. I've got many words for my thoughts on it already but I'll wait a little longer before posting them.
For now, here are some shots of the internals and tubes that came stock. From my basic research they appear to be some of the best you can get for the tube types.
6N6p are from the Novosbirsk factory, with Philips Miniwatt 6x5GT for rectifier.
I fancy a Bendix 5852 for rectifier but I have zero desire to roll the 6N6p quad. The type included as stock are some of the best you can find, it seems.
Genya's performance in stock – coming from an Atlantic prior to this – is, frankly, incredible. It's a huge jump up.
Others will know more than me regarding tubes, but the itch to roll is just not there for this unit. Taking off the cover is a pain, which a good thing imo. Stops you from tinkering!
I'll write up proper impressions after a few 100 hours or so, but thus far today is the best audio I've ever heard. Genya looking like a killer deal.
Genya internals:
PXL_20250708_203302446.jpgPXL_20250708_203312938.jpgPXL_20250708_203602092.jpgPXL_20250708_203618000.jpgPXL_20250708_203435277.jpgPXL_20250708_203342892.jpg
