No exposed tubes in the Genya. There are 5 in total; 1x 6X5 rectifier, 4 x 6N6P dual triodes as input buffers as I understand it. All under the top cover. Ran surprisingly cool in the rack. I could put my hand on the top cover without any concern.The Genya might be an interesting choice for my bedroom for late night listening through my Stax 009 electrostatic headphones. I’m wary of putting a tubed Lampi DAC with exposed tubes on my bedroom nightstand. Sleepily I might scald myself on hot tubes! I assume it doesn’t run too warm. I use a Stax tubed amplifier to drive my 009. That has two small signal tubes and doesn’t run too warm. I have an Eversolo streamer, and I could plug that into the USB output.
The rectifier in the Genya is the 6X5/EZ35 (as used in the Amber series). It's perfect for the E182CC tubes.Looks like the rectifier is different from the usual 274B as well.
Pricey tubes are a investment like 401kIt looks to me like Lampi is the Shindo of DAC manufacturers. Every new DAC design uses a different tube set. Kind of makes it harder to upgrade if you have a lot of pricey NOS tubes.
And to add to the perturbation of tube combinations, there is a "hot rod" version of the Genya that includes different (more exotic) tube sets.It looks to me like Lampi is the Shindo of DAC manufacturers. Every new DAC design uses a different tube set. Kind of makes it harder to upgrade if you have a lot of pricey NOS tubes.
Rumor has it that hot rod option ain't going to happen.And to add to the perturbation of tube combinations, there is a "hot rod" version of the Genya that includes different (more exotic) tube sets.
Let me rephrase then; there was a "hot rod" version of the Genya that included different (more exotic) tube sets.Rumor has it that hot rod option ain't going to happen.
Lampi, unlike Shindo or brands with a similar mentality, do not base their production on obscure tube sets and in fact they did a whole range re-thinking a few years back on that principle alone.It looks to me like Lampi is the Shindo of DAC manufacturers. Every new DAC design uses a different tube set. Kind of makes it harder to upgrade if you have a lot of pricey NOS tubes.
Thanks so much for your impressions. Was considering a MSB DAC (reference) in the future, but how would you compare this to the Cascade? That could change my mind.....I just wanted to post about the Lampizator Genya , I was able to set it up this afternoon . I only listened about 20 min but left it playing in hopes to listen more tonight . I was shocked and did not expect what I heard in this short time . The Genya is a bargain , I always felt the TRP was best value but now it's the Genya for sure . Another feature I like is you can put it in the rack no need to be ontop . I will be moving to Genya to my Headphone setup in another room it will fit my rack perfect .
Hoping to hear others thoughts on this excellent DAC in the near future.
The Genya is not in the same league as the Cascade but we are talking 5x the cost . You would be closer buying a Horizon 360 .Thanks so much for your impressions. Was considering a MSB DAC (reference) in the future, but how would you compare this to the Cascade? That could change my mind.....
Yes - the Genya is getting USB output from the A8. The A8 is a surprisingly good component. The Genya is still large, but obviously no tubes sticking out.Great write up, @jakezboulder. I’m interested that you use the Eversolo DMP-A8. I have now two of these server/DACs, one in my bedroom with a Stax 009 headphones. I’m trying to see if I can fit the Genya into my bedroom setup. My Lampi Pacific is too large and I don’t want exposed tubes in my bedroom. Too risky. But the Genya might work. I’m guessing the Genya is being fed the USB output from the A8.
As a current Atlantic owner this is good newsSublime, and Surreal
The Genya is my 7th LampizatOr DAC. From 2014 to 2021 I had a Big 5, Big 7, and then the Golden Atlantic TRP. In 2021 I moved to a Tiny House, and then to a boat, so sold my entire system. In that interim I had the Amber DAC/Amp, and then the Fezz Equinox (this is a damn good DAC for the money). Recently I moved back to a house, and am rebuilding a system. I picked up where I left off with the Atlantic TRP. A month later the Genya was announced so I jumped on board.
For reference I’ve also owned many Linn DAC/preamps (prior to 2014), a Meridian, 3 different Wavelength DACs, and the Chord Hugo TT2. And for reference, the Big 7 as it was, to my ears, is better than all of these. I also considered the Atlantic an endgame components – one I would been happy to own and listen to to the end of time. Even with that I was intrigued by the Genya and knowing what Lukasz could build.
I feel like I’m pretty familiar with the LampizatOr ‘sound’ and what to expect from a LampizatOr DAC (or so I thought), which is why it was a no-brainer to come back to the Atlantic when rebuilding a system.
The Genya though is something different entirely. I don’t know if it’s the particular tube, the no frills design, or the Horizon engine, but the sound doesn’t fit with the other LampizatOr DACs I’ve heard. For me, I’m still listening going back and forth between the critical listening and uncovering what’s different and what’s there, and just the pure enjoyment of listening for the sake of listening.
The primary characteristics I would say is sublime. That says everything and nothing. Honestly though it’s hard to describe. At the beginning I added surreal – again everything and nothing – I’ve never heard anything like this.
Does it have all the good sound stuff – soundstage, depth, breadth, clarity, smoothness – absolutely! It is better than the Atlantic – absolutely. A couple others have said it may lack some bass – I can see that – and I’m fortunate to have both volume and crossover knobs on my speakers for bass, so I’m spared any lacking in that area. I did have to turn up the volume a few notches compared to the Atlantic though. Someone also said it seemed to have a more natural decay off notes, and I would agree with that. It seems to do well, as every LampizatOr I’ve heard, with almost any music or style. Brass and horns, women’s voices, piano is particularly good, hard-core rock, blues, and so on. I’ve had it burning in for about 200 hours now, it took at least 100 hours before it started to open up and sing.
I don’t listen to classical or symphonic music much, still I played some to discover more in the Genya. After listening to a few tracks, I am inclined to explore this part of my collection more. Each instrument – brass, woodwinds, strings, harpsichord, percussion – had a beautiful sound and intonation clearly distinct from all the others.
I played my favorites tracks – tracks I’ve played for decades – Chris Rea, Sarah McLachlan, The Wailin’ Jennys, Traveling Wilburys, Mark Knopfler, Blues Brothers, Ebba Forsberg, Jesse Cooke, and others. Perhaps it was lacking a stereo for over 3 years, but every song is even more of a joy to listen to. There have even been a few moments that I would call a double-take – I’m a bit stunned at the sound and what I’m hearing that I just freeze and listen deeper.
While I miss the glow of the tubes, and that box takes up a lot of space – the Genya is an stunning DAC. I have a new endgame component!
The rest of my system – Don Sachs Valhalla pre-amp/amp, Eversolo DMP-A8 streamer, Vaughn Zinfandel speakers with built-in subwoofer in each speaker. Speaker cables are Linn; VooDoo power cables for the speakers; IsoTek power bar; and the rest is Sablon – USB, interconnects, and 3 power cables.
