QSA Landeri Veridion Discovery
Jeff4598
Active Member
Feb 29, 2024
125
96
33
69
07960
Recieved my ($250) AC cable and replaced a $1,300 Alan Maher AC going into my distributor.
I doubt it is fully broken in yet but much to report.
If I take apart the word psyco-acoustic I would say it's 70% psycho and 30% acoustic.
The flow of music and emotional connection is massively improved. I hear the intent of the music and somehow "get" lyrics in songs I have known for 50 years. Remarkable experience.
Sonically, there is greater tonal complexity, details of inner dynamics, image solidity, powerful bass and impactful but nonirritating treble.
This from a scrawny $5 Amazon spaghetti - like AC wire feeding the entire system.I don't normally play music unaturally loudly but I am blasting it for break in and somehow this little thing allows my system to sound less strained and more dynamic at very loud levels.With my door closed and two rooms away I feel like I'm reurning from the restroom at a live concert-down the hallway but it's live and exciting and expressive.. This is MUSIC!
Quality is far from proportional to price in audio but I am looking forward to trying one of the "better" QSA cables. I really thought I would have to do a major equipment upgrade to get this kind of sound. I have heard many systems that are big and impressive sonically but only a few that are this musically emotive.
Bravo!
After the AXPONA 2025 QSA Lanedri demo, I purchased 2 QSA Landeri Veridion Discovery PCs. Heard good things about their Ethernet cable as well so will be purchasing also- relatively inexpensive to try.
I received my second Veridion Discovery power cord this afternoon. The first one went to the end of the captive cord of my LG OLED (via an adapter). It hasn’t moved as the improvements to the quality of sound and video made the cord well worth the cost. The second is targeted for my AV receiver but I plan to experiment in a few different places before finding its final resting spot. It’s presently powering the power supply feeding my router.
I ordered an Ethernet cable as well. I was told that this would be ready at the end of the month.
Reactions: keithc
I would be fascinated to hear a comparison between one of your none Veridion but much "higher level" QSA- Landeri cords and this little guy with the Veridion treatment.
Note in this reply to me from Romaz, he mentions that "the smaller gauge of the Discovery will hinder" current-hungry devices. On such devices, one would be able to "adequately assess Veridion's qualities" but for a fair fight with one of the Gamma cords, I think it would be best to do the comparison on a component that's not current-hungry. But I can still give it a go. It's a bit easier now given that I have a second Veridion and one of them is very likely fully burned in.
I am using the Diacovery as the first wire into the system fom the wall. Better dynamics than prior cord. Have a Goldmund 590 int amp and speakers with powered woofers. Not a direct comparrison to a Gamma but Discovery replaced a moderatley hefty Alan Maher cord and seems to restrict current less. Everything is relative!
Fascinating- thanks for sharing.
The first Discovery didn’t last long on my K50 as I wasn’t patient enough to put up with the burn-in rollercoaster on my big rig. It went down to my TV more out of curiosity as to how apparent it would be visually. To my surprise audio quality was noticeably improved as well when streaming using one of the apps on my TV. What I heard and saw brought it closer to what I get from 4k optical discs. I had intended to only burn the cord in on my TV but the improvements was enough where there was no way that I want to be without it. I will try to be more patient with the second cord. LOL
One of the most impressive things I heard from QSA-L is the Gamma Infinity Ethernet cable. A friend brought his over and the improvement was on par with a better audiophile switch (though a better switch is still necessary). I am very eager to hear the Discovery ethernet.
I did it sorta the other way around with the Disco AC. TV first and yes much better sound (just bthe flat screen speakers) and richer color and most noticeably better motion- easier to keep track of 10 basketball players moving ( I guess the equivalent of PRAT).
After 8 days on TV I moved it to the audio system and it was still >300 hours untill it maxed out.
Reactions: kennyb123
…. To my surprise audio quality was noticeably improved as well when streaming using one of the apps on my TV. …. I had intended to only burn the cord in on my TV but the improvements was enough where there was no way that I want to be without it.
Seems like a significant TV cord upgrade at a very reasonable price. I’ll likely test/swap all myTV PC to QSA-L-Discovery
Yes it is. My LG OLED has a captive power cord so I purchased an adapter that would allow me to use the Discovery as an extension cable. I suspect the people most happy about QSA-L offering these Discovery Veridian cables only for a short time are the other audiophile brands. No way that they could make $250 cables that perform at this level.
I have been using a Nordost Heimdall 2 power cable on my different tv's since 2012. Whether LG or Sony I will solder the wire directly into the spades of the plastic power connector that inserts into the PCB of the TV. This gives a direct connection rather than using any sort of adaptor. It is a PITA to do initially but I usually keep a TV for 5 years so its worth it.
Good to see QSA applying their conditioning tech to a cheaper cable, just wish it wasn't a $2 PC ac cable.
I imagine that will produce better results.
What would be fascinating to learn is how the fully-treated generic cable compares to your Heimdall 2 even when an adapter is used.
Fry a $2 cable and sell for $250. Makes perfect business sense if people bite. The guy in HK who came upon with this years ago was offering to fry anything you chose to send him, any cable, device, fuses, your car and rice cookers (very popular in China, a bit like toasters in the West).
"Veridion" just seems a different marketing approach, which is important to the success of most consumer products. What is sensible when creating a new brand name is to check it on the trademark database. Unfortunately there is a trademark application for "Veridion" by a Chinese manufacturer of cleaning products.
I would never buy a technology-based product, audio or anything else, from a manufacturer that is opaque about its technology, but I do like good marketing. If you have a 2000% mark-up, you don't need to sell much to have a nice business. It can cost a business more to create the brand value than the products themselves. This is common in many industries, like fashion and cosmetics. My cousin was CEO of the UK's largest AV and mid-fi retailer, they made more money on selling insurance policies than they did on the hifi product.
Why do you continue to seek out qsa threads to spam? It just seems like an unhealthy obsession given you have no experience with it or intention to gain any.
Churchill is widely credited with having said this: "A fanatic is one who can’t change his mind and won’t change the subject". Seems apt.
Best to report his post.
Reactions: ticktock
@ssfas - You have been warned so many times about doing this exact type of thing, you will no longer be warned. You will be permanently banned from the WBF. I am posting this one publicly, so everyone knows why you are gone. Your final warning was issued on May 29th and you knew the consequences if it happened again.
We wish you well in your audio journey.
Tom
All due respect to what you are saying. I find many tweaks etc useless but this is the real thing.
Tom
Another one bites the dust! Ah well, feels a bit more open-minded around here.
I am curious. I purchased 7 Veridion Cords for my TV's, JVC Movie Projector and all the components in my media closet. I have one TV that I cannot remove the plug from. If I understand you right, you purchased an adapter for that plug. My question, if I can make sense, is....would it be the same effect with an adapter vs going directly into the TV with the Veridion?
I suspect so.
I saw and heard positive benefits from QSA Jitter Plugs. These affix onto the end of existing power cords. So when a friend mentioned using an adapter with the Veridion, it seemed plausible that it could provide benefit when being attached in the same way a Jitter Plug would be.
What the QSA-L DC extension cable showed me as well is that the QSA treatment can still be beneficial when it’s being fed from another cable. These extension cables punched way above their weight.
While having end to end treatment is best, a good amount of the QSA goodness will still come through even if we are forced to piece things together with adapters.
Reactions: Willgolf
