Review: Snake River Audio Takshaka power cable
I had a different experience with adapters. I've got a pair of Voodoo Cables 15A to 20A adapters that I used on some Elrod Master Diamond PC's to try them on my CH Precision M10 stereo amp at the time, and when I pulled the trigger and got the exact same PC design with purpose terminated 20A ends for this application the SQ improvement shocked me. The adapters were definitely degrading the performance in my use case. Not what I was expecting....
Did you use the "Premium Silver" adapters at $249 or the more generic looking $89 version?
What an unfortunate name for a company, sounds like someone is having a laugh. ;)
$89 versions. It would be interesting to see if the $249 silver ones fix things, because for me it was definitely a problem of SQ loss.
Reactions: Paul1960
I'm guessing the comment was about VooDoo Cables. But I suppose Snake River might conger "oil" connections, too.
In my humble and relatively sophomoric journey compared to many of you, there's nothing more important than direct experience of a new cable/component/accessory in my own system to my own ears. I think all of us have had the experience of buying based on advice or reviews only to be underwhelmed. This is why it is so critical for manufacturers when possible to allow a solid return / trial policy, and for my situation is often a decision factor to try something new. Jonny/SRA is very good about his return policy and allows a user to decide for themselves.
Totally agree! Try.Keep.Not.Return. It should be that simple, but not many manufacturers are willing to offer such option.
I used a Shunyata adapter (will list soon) to test. Not exactly the same, but not much degradation. Basically to see how certain PCs perform in the system before committing with the C19 connector.
Hello and good afternoon gentlemen, we are not other forums, where you can freely go so completely off topic that the thread ends up in a different stratosphere. Some posts have been deleted.
Please stick to the topic, on this and other threads as well. The recent posts were disappointing, to say the least. Here at the WBF, we are better than this.
Tom
Reactions: dwinn
Here is my take on adapters. You are welcome to accept it or discount it.
If I am not mistaken, @keithc hadn't even heard about Snake River Audio, until a discussion about the SDFB (Swiss Digital Fuse Boxes) adapters came up. Folks did not want to spend another 1 to 17K on another PC in order to use the SDFB without restrictions or a change to their system's performance. My thing was (here and on the 'Gon) that adapters thwart the efforts made by the SDFB itself. In other words, it was restrictive. In further talks with Mark (the designer of the SDFB itself) and other members here and over at the 'Gon, it was revealed that adapters were not a good option and that it hindered to severely hindered the performance of the original cable. This, from many users.
This is why I suggested to Jonny to possibly consider a "Pig-Tail" (a short, 8" Takshaka or Signature PC) into his line up, so that those that had the SDFB would not be hindered, or at least they would have the option of possibly having better than the original cable (no matter what one uses), as to not severely thwart or hamper the system's performance. I have learned that even an RCA to BNC adapter caused months of issues with an Esoteric transport I have. While that may not be a PC, which we are talking about here, it did create issues that basically rendered the unit useless for months on end. Along with a plethora of frustration.
As soon as I got (thanks to Jonny at SRA - and at no cost to me to try BTW) the "proper connections" on my replacement cable? There have been ZERO issues ever since. Like, not even so much as a hiccup. That was a learning curve for me, as I never in a million years would have EVER thought an adapter would make such a difference. I paid for that replacement cable the very day it was delivered. Jonny really DOES care about customer satisfaction.
When it comes to PC's, I have no such experience I can share with you, but I will say this. Why go from a properly and superbly well designed cable with three different metalurgies, along with advanced shielding and other design parameters, only to "Govern" those efforts with an adapter, that can thwart the entire effort and introduce possible EMI/RFI?
This could be the difference between "THE" cable and a cable that.....eh, "made a change for the better". From the micro-dynamics, to the macro. From the presentation to the aura and space. From the full frequencies, to a tonal shift. From palpability to WTF is that smeared or altered image? From a timbre that is unfathomably realistic to one that may be, let's just say....not so on point. These are just but a few of the parameters that can change with an adapter.
All metallurgies have their differing attributes, as well as deficiencies. Snake River Audio has a mix of three, with other technologies mixed into the equation. Why take all of that and add a restricted signal or "governor"? While the connection may be solid and one gets sound with no issue, one does NOT get the full flavor of all of the attributes the original cable has to offer.
I am and always have been a believer of this. Your system is only as good as your weakest link. It's best to get the proper terminations IMO.
Tom
Here is an example of a custom-made 16-inch Takshaka (0.5m) next to the 8-inch version; I needed something that was slightly longer than the "SDFB shorty" version but for components adjacent to my power conditioner it was less messy than having runs of cables behind my rack. As usual Jonny's workmanship is great and I encourage folks to reach out to him for any specific lengths/needs.
If folks only knew....
Tom
Hi all, I’m new to the forum and wanted to chime in on this thread.
I’m a big fan of SRA cables and I’ve been using them in my system for the past two years. I also had the pleasure of meeting Jonny face-to-face twice over the past two years at capital audio fest. Although I don’t have a full loom, I have his signature Amp series power cord, the Signature series Mamushii interconnects, Signature series speaker, cables, as well as crossover cables and a boomslang USB cable.
Each addition was a game changer in my rig and I’m so glad that Jonny is getting the recognition he deserves!
Thanks to this thread, I was convinced to try a TakShaka shorty and ordered one as part of the July 4 sale. Jonny is breaking it in right now and I anticipate it being shipped by the end of the week. I have previously used Verafi’s piggy, and then later the Amazon adapter, so I’m really hoping the Shorty makes a difference!
@keithc thanks for the wonderful review, and @treitz3 thanks for suggesting to Jonny there might be a market for a shorty.
I've thought several times over the past couple years of adding one of Mark's SDFBs to my kit, but I knew in my gut the rat tail was going to seriously hamper performance and, like others, I didn't want to sink $x,xxxx to get the stock cable out of the way. Lovely to see there is a serious option now... :)
  • Love
Reactions: keithc and treitz3
I am very intrigued. Before asking what is in my mind, please allow the following precept. Cost and performance and not necessarily linked in audio! With that said, does anyone have a sense of how the Takshaka would compare to a Transparent Opus?
I cant answer that question but to put things in perspective if you read my review the Snake River PC bested my $17K Master Built Ultra Power cord at a fraction of the cost.If I were to guess it is all in the metallurgy used in the Snake River. I have no pony in the game but it really is exceptional
Wow!
I cant answer that question but to put things in perspective if you read my review the Snake River PC bested my $17K Master Built Ultra Power cord at a fraction of the cost.If I were to guess it I all in the metallurgy used in the Snake River. I have no pony in the game but it really is exceptional
That is a strong statement! I know you have been a big fan of the Masterbuilt, too! Thanks!
I have no right to ask, but as you do the best you can with an exempliary system; do you intend on replacing the MB Ultra PCs with Snake River Takshaka PCs?
Did you read my review. The answer is No. Yet having said that the Snake River clearly bettered my MB ULTRA PC
  • Sad
Reactions: dbeau
If I were ever going to make a change it would be for an entire loom not just a PC
