(...) certainly Charles has subs.
My mistake, I was thinking about another XVX system in WBF that does not have them. Thanks for correcting it.
That’s not possible unless he was suffering from a condition he no longer has or he purchased hearing aids. Human hearing does not improve after age 40. It diminishes slowly over time.
Sure if that's what he meant.possible Charles is referring to 'listening better' as opposed to 'hearing better'. just a guess on my part that makes sense.
there is a learning factor and development factor to the art of listening. matters of recognition and understanding. some of which is related to getting an ear for particular types of music appreciation.....which is a process that mostly does improve with age (to a point). and even our system development can be helpful to open doors to better listening by allowing more types of music to work correctly and sound natural. even finding proper SPL's for extended sessions plays a part.
just seems like how it has gone for me. i have more understanding in my listening now at 73 years old, than ever. but were my ears better at hearing at 43 years old in 1994 when i got serious about hifi? i suppose but hearing is just a tool. what do you do with it?
Thanks so much. I have owned a Maxx3, Alexx, and now an XVX. Although one would think that using HP/LP would be superior to full range, i have repeatedly tried this route and each time running full range has been noticeably superior. Wilson recommends running full range. The good thing about big Wilsons is that they are extremely resistant to overload in the bass range, so no need to be concerned over this running full range. It's not an issue.Hi Charles,
I genuinely enjoy reading your posts which exude passion, conviction and also a pragmatism and candidness which is refreshing
Regarding your XVX/Wilson Crossover, do you cut off your XVX and bring in the Thor underneath, or do you run the XVX full range and then utilize the Wilson Crossover to fine tune only the Thor? Most owners of big Wilsons I know tend to run full range and blend in the sub. I do as well...but I also am contemplating going with substantially more subwoofer air dispersion capability...and then actually seeing what happens if we relieve the XLF of sub 45hz or sub 35hz duty.
thanks for any insight into your own system...but also any insight into relieving the mains of low-end duty to give them even more enhanced mid-bass capacity.
Thank you. Very good to know. How high up do you run the Thor? I read often owners go to 38hz.Thanks so much. I have owned a Maxx3, Alexx, and now an XVX. Although one would think that using HP/LP would be superior to full range, i have repeatedly tried this route and each time running full range has been noticeably superior. Wilson recommends running full range. The good thing about big Wilsons is that they are extremely resistant to overload in the bass range, so no need to be concerned over this running full range. It's not an issue.
Thank you! That is super-helpful. Yes, our XLFs are from that manufacturer's refurbishment program...our color, full 5-year warranty and a small fraction of the original price...plus full return/credit of the original price of the X1s bought 10 years prior...now that is pretty good service!LL21, I run my Thor LP at 30 Hz. Did you know that Dave Wilson designed the Thor especially for the XLF? Wilson has a refurbishing program so I'm sure Thor's are available. I use a horizontal lie, in plane, and equidistant between my XVX. Works wonderfully. The Thor has enormous output and was meant to be used with the XLF in what he referred to as the "music position" as shown on the Wilson website or my pic. It has a sensitivity of 93 dB and is almost impossible to overload. My MC2.1KW has enormous output but clips before the Thor.![]()
What do you use for streaming from Qobuz?Honestly, my streaming system sounds better than my CD's and SACD's and they are all present on Qobuz.
Well, AQ has so many names for their cables I thought maybe I'd made an embarrassing mistake, but indeed I pulled the cable and it is a Coffee Digital Coaxial Cable. It is not listed on the AQ website so it may be discontinued. I don't know much about it because my dealer gave it to me as a gift. It connects my MVP851 DVD Player that has to be 25 years old to my MCD12000. In reading about it on the internet, it is 10% silver and apparently a very fine digital coaxial cable, I only have one. The other digital coaxial cable is a Wel Signature that connects my MVP881 BR Player to the MCD12000. You had me going for a minute.Charles whats up with the Coffee digital coax cables ?
Your not gonna tell me your coffee machine is digital are you lol?
I think amps are compromised with high distortion by bass speaker and sub driver's pressure.LL21, attached are some pics as I promised. But it's basically the music position for an XLF or XVX as on the Wilson website. The above is what makes Wilson such a great value. I was going to buy an XLF and actually irritated my dealer when I didn't. I'm quite happy with my XVX but honestly, the reason I didn't was because the XLF was a bit too wide to easily accommodate a Thor between them. Strangely it's the width of my room, not the height, even though my room is an A-Frame that causes the XVX to be the better speaker for my particular situation and that's why I bought it, over the XLF. The super tweeter makes a huge difference and also, I really don't think there's that much difference in the tweeters between the XLF and XVX. So, you have a great speaker. It's a lifetime speaker, a keeper.
I agree 100% but I really have no choice. I you look at the position of most amps in a system like mine relative to the huge subs, the subs are usually in the corners and the amps are between and in front of the subs. Look at the setup of the WAMM's at Munich. The problem is much less of a concern with my solid state amps than with my 3500's. With them I use a glove and check the tubes for snugness almost every time I play the system. The heat expands the sockets and they tubes are extremely secure with only minimal vibration to the amp, but ideally the amps should be out of the sub sound field. I use Wilson Heavy Pedestals, four of them per amp to reduce vibration as much as possible. My amps are on heavy granite slabs. When I place my hand on the 3500's with extremely heavy floor shaking bass there is almost zero noticeable vibration. The Pedestals are extremely effective. Tubes are like connections to speakers. They can work their way loose and should be checked often. I check mine essentially every time I play but have noticed no problem. But as soon as you quit checking speaker connections or your output tubes, that's when the problem arises. Complacency is a killer.I think amps are compromised with high distortion by bass speaker and sub driver's pressure.
Not best position in my opinion.
The Thor has no connection to the XVX. It is an entirely independent system run summed mono using the Wilson ActivXO electronic crossover as recommended by Wilson. Because of its central location, LP only at 30Hz, no HP, I do not have bass localization. The phase is set at zero because the Thor is essentially in the plane of the XVX. It's a nice reasonable setup but not ideal. I could put dual Subsonics in my corners, but this would not solve the problem of the amps being in front of the subwoofers. I think that a system like Mike L's is ideal. He has his huge subs in front of his amps, if I remember correctly and with excellent racks for vibration control of all gear. This can improve your sound very significantly. I've done the best I can with the funds i have.Does the Thor have independent connections to each speaker?
I was told to never push my tubes all the way down. That can stretch the prongs over time and create loose tubes. Best to set them where they are snug then stop pushing them down. That way the spring in the pin sockets stays tight.I agree 100% but I really have no choice. I you look at the position of most amps in a system like mine relative to the huge subs, the subs are usually in the corners and the amps are between and in front of the subs. Look at the setup of the WAMM's at Munich. The problem is much less of a concern with my solid state amps than with my 3500's. With them I use a glove and check the tubes for snugness almost every time I play the system. The heat expands the sockets and they tubes are extremely secure with only minimal vibration to the amp, but ideally the amps should be out of the sub sound field. I use Wilson Heavy Pedestals, four of them per amp to reduce vibration as much as possible. My amps are on heavy granite slabs. When I place my hand on the 3500's with extremely heavy floor shaking bass there is almost zero noticeable vibration. The Pedestals are extremely effective. Tubes are like connections to speakers. They can work their way loose and should be checked often. I check mine essentially every time I play but have noticed no problem. But as soon as you quit checking speaker connections or your output tubes, that's when the problem arises. Complacency is a killer.
