LampizatOr Baltic 3
If you are sure you're in USB mode, my next suggestion would be to try a different rectifier tube. Even if the other tubes are lit, a failing rectifier can cause you to have no sound in either channel.
Is this Rob? Thanks for the input.
I did swap out the rectifier but even though I get high voltage at some of the tube pins I still have no output on either channel. The USB button is pushed in and Roon recognizes the B3 and acts as if music is playing so I assume that the USB board is on and working. Looks like a warranty return...
This is not Rob, but if you've been speaking with him I'll give him the nudge and let you two continue the trouble shooting directly in an appropriate protocol.
I did contact him a couple of days ago. He was going to speak with tech at Lampizator. Have not heard back so I am trying other "protocols".
Since this is a thread dedicated to the B3 with lots of experienced users it seemed like a good place to try. Seemed appropriate to me especially since Lukasz checks in periodically.
Hello all,
My name is Jay and I am a new owner of the amazing Baltic 3. Great to be a part of this forum and thread.
Welcome to WBF, Jay! Congratulations on getting the Baltic 3!
Reactions: Miki70 and dreamer
I found the problem. I decided to open the case to check if it was just a loose connector. Normally I would not have risked losing my warranty but I was going to have to pay $280 to ship the unit to Poland so I felt that I had nothing to lose. When I bought the amp three years ago there were two repair techs in the US.
The box must have taken a rough hit by the moving company during our family's recent move from DC to CA. One cap was completely separated, rolling on the case bottom, and the other 3 were dangling by one lead! These are the output caps, needing four for balanced operation. That explained why everything else seemed to work but the output.I saw no sign that the caps were originally held in place with more than the solder joints. Given that they are quite large and heavy they just could not take much movement.
Rob kindly and remarkably offered to pay to fix it locally. I figured that my warranty was toast anyway, and I did not want him to pay for my physical damage, so I temporarily soldered the two the singled ended (RCA) caps in on the top of the analog board and it worked. Putting all four back under the board took a lot more effort. I have been building and modifying audio equipment for about 40 years otherwise I would not have tried this. Hint: use your cellphone to always document the wire positions if you are going to be unsoldering and disassembling.
Anyway the DAC sounds great again with my LTA amp and a pair of Beyerdynamic HD800S headphones...
****Update: Rob said that my warranty (5 years) would remain intact. Much appreciated...
Proof of life with most recent tube choices...
Valvo AZ1
Cunningham 6F8G
Bendix Eclipse 12AU7
Great tone, detail and depth... a good pairing.
Reactions: Miki70 and NickMimi
Valvo AZ1
Cunningham 6F8G
The 6F8G is a cool looking tube! I’ve never tried them as they have basically the same spec as a 6J5 which I have many of. I’m curious to know if you’ve compared them to the 6J5 and if so which brand/style and what do you like more about the 6F8G?
I have Cunningham/RCAs in my B3 but have tried other brands in an old SinglePower head amp I used to own. The tube I would like to try is the 76 but I cannot find the adapter for it. I know they used to make them.
Well, kinda. The 6J5 is more like an ancestor. The 6F8G is essentially a 6SN7 as there are two triodes within.
Cheers,
Robert
Reactions: Designsfx
Ordering the Engine upgrade for my Baltic 3. Hoping to get the shipping and the overall process go smoothly!
Reactions: christoph
Let us know how you like it. I am in the US which no longer has a tech support location so I bailed out on the upgrade when I considered shipping to Poland...
Did you ever find adapters for the 76’s to try?
I never did. Those tubes are gathering dust...
I am also in US (Chicago) and thought about it, but Lampi US assured me that everything should be fine . Sent it from Chicago last Friday and it was delivered to factory today. Waiting fingers crossed. So far so good.
I was not concerned about the distance. I was concerned about the considerable shipping cost. What did shipping cost you?
Lampi US asked me to use pirateship and use UPS as carrier which I did. I think it is a third party shipper where one can save cost. It was about $350. The Import and customs at Poland is taken care by Lampizator.
Reactions: NickMimi
I received the updated unit. No physical differences. The gain switch is de-activated so it is constant gain now. Now the sound: initial impression, it sounds amazing. More body to midrange, very enjoyable highs and more and more punch to bass. The biggest difference is the soundstage and imaging. It is almost a 3D effect now dancing around!
I also re-built my HTPC with some better components, rolled some tubes (RCA 12BH7A Long Black Plates pair, Shuguang WE6SN7 PLUS pair, KR Audio 5U4G rectifier) and it is the best sound I ever achieved.
Anyone running the B3 with volume control as a preamp into a power amp?
If so, how does the sound differ compared using a separate preamp?
