Building field coil speakers Rullit Aero
My pleasure, Lautreamont!
Yes, you're correct. The Qts parameter of the driver changes value with voltage, which may allow for use in different applications. Low voltage results in high Qts, which can work for a sealed enclosure, or open baffle design. Conversely, high voltage lowers Qts, which may work well for a ported enclosure. Of course, there are always trade-offs. Lowering voltage for a high Qts comes at the cost of sensitivity.
This is very satisfying and good news - thank you very much. I appreciate all the informative posts on this forum - I learn something new every day.
I will try to investigate the matter more in the coming time and then come with a conclusion. It seems that there's a hope that I can find a cabinet that brings the best out of the Rullit and then match it with a single ended amplifier that produces enough power to tame the "beast" of the field coil while ensuring that there is room enough in my apartment.
Reactions: dcathro
Thanks for the shout-out Ken!
Lautremont,
I make complete speakers using the Rullit Aero or Super Aero. In my experience with them, I have found them best suited in more of an open-baffle design. I experimented with open-backed boxes (along with a myriad of other variants) but I did not personally like the color they introduced. I did also find that in an open baffle, the 10" drivers start to roll off perhaps around 90-80hz (its a rather gentle roll-off) and the 8" is probably around 120-130hz (its open baffle, and field coil, so there are a lot of other variables at play) I could enjoy them without any bass augmentation, but they do require a low woofer to complete the sonic picture.
I recommend for our speakers 2ft from the face to the back wall as a minimum, with 3ft+ being preferred.
@TKK has my speakers in his apartment space, he might be able to chime in a bit as well as to how they perform in such environments.
Lautremont,
Hi Rich,
I am curious, at what frequency do your woofer start to roll off in the open baffle?
I know people worry about overloading small rooms, but I have 15" field coils in 130L ported boxes (tuned to 35hz) with open baffle wideband (170 - 6khz) in a small 15 meter sq room. I have the speakers (acoustic center) 3' from the front wall, but the speakers close to the side walls to get bass re-enforcement.
By the way, it is great that you and Ken interact with the DIY guys and give advice. It really does elevate this forum in my opinion!
Lautremont,
Thank you very much for sharing your experience. I agree with @dcathro - it is truly amazing that you take your time to visit these forums and share your thoughts. It shows great and genuine character.
I have seen videos of people using the field coil driver as the only single unit but it also makes sense with a woofer. I think the choice of enclosure will probably deduce if I need a bass solution.
I hope TKK will find his way to this thread and share his experiences as well - I hope that a lot of people can learn from this thread.
Reactions: Artnet
