I have a late 80’s NOS Blackheart in the drawer which I might pair up with a Riverside TD-124 MKI when I get around to it .it also measures more linear than many of the Koetsus
I shipped a FR64S to Richard Mak and had it converted to 66, new Abec9 bearings and continuous wiring from cart clips to rca
It sounds very good with NOS Kiseki Purpleheart
I decided to go with Yamamoto titanium H6S headshell - you need to drill a little to make holes bigger but the titanium helps cool the dava vs wood and you can adjust azimuth so went with this. Arche seems to complex - need PHD - NASA experienceI have my arms in Singapore for rewiring
I have waited 7 months as a project to get my table - in another month I am optimistic I can share with the world
Another problem with small fixed holes is setting zenith angle.what if correct alignment ends up between two holes?
I´d have a pro mechanics cnc the row of holes into a continuous track like normal
I have always had success with reaching Darius at:With regards to ordering a DAVA SOUL & DAVA MONO & DAVA TUBE PSU from Darius, I have tried the both service@cartridgeretip.com & Dava@dava-cartridges.com, but am unable to connect. How else can Darius or an associate be contacted to order these cartridges, is there a WHATSAPP available, I feel like that would be best as I communicate with everyone and their mother that way.
Thanks,
DC
+1-919-641-5483 (WhatsApp & cell)
lovevinyl1212@gmail.com
dariusvaliunas@gmail.com
I'm expecting my Soul to arrive sometime in May which I ordered in December of last year.
this is why I dropped that particular headshell
I got the H6I did get direct wiring but have both Yamamoto HA-1 and Harmony magnesium that fits
A bit OT, but I like the casing of your phono preamp!I ran the DaVa Soul at AXPONA on my SME Model 12 Mk2 with a Series V tonearm that SME was able to wire with 6-conductors to accommodate the field coil. I was beyond pleased with the results, and really made the new Treehaus LCR phono show what it was capable of. You can see the FC wires from the bottom: SME made a nice aluminum piece with a standard DC plug to attach your power supply of choice. To the casual observer you wouldn't realize it was a customized build.
What method do you use to set and check the Zenith?Another problem with small fixed holes is setting zenith angle.
I set it first visually by aligning with protractor then I finalize it by AM software.What method do you use to set and check the Zenith?
