Really? Have others reported that experience as well? When you say give the input selector a spin, does that mean yours is one with a rotary knob on the back or do you mean metaphorically? I can only change input selection using the remote. And it has never not been on the input I left it on previously.As for initiation- if I’m understanding you correctly I ALWAYS have to give the input selector a spin in order for the dac to find the input after startup- even when using the same input from the previous listen. It drives me crazy but it seems that’s just the way it works.
Cheers,
Robert
