Hi @CKKeung ,
I understand your concern. This is one of the reasons we picked Acrylic as the footer material. It’s a “hard” material avoiding the mass-spring resonance which makes things unpredictable, especially when taking a rack into the equation. Acrylic is still softer than anodised or coated Aluminium. Softer, rubber materials can stain surfaces over time. It doesn’t leave many other options, fabric, velt, leather are good options from preventing damage, but those do leave a very audible footprint unfortunately.
So far though, have not managed to damage anything with the stock Acrylic footers, just make sure they’re clean before stacking.
Have you had the opportunity to listen to the I/O / Olympus side by side vs stacked?
I have. There is a benefit if you separate them. How big that benefit is really depends on a lot of factors and would be system-dependent.
We are setting up our room in Dallas:
Come say Hi in the Stemmons C room if you are at the show.
As part of the setup, I initially had the Taiko router on the floor, because my room partners wanted to display a turntable and we didn’t have enough shelves on the rack. I found a set of HifiStay Absolute Point feet and placed them under the router (while it was still on the floor). The improvement was so significant that we called a meeting and decided not to install or display a turntable. Instead, we used that shelf for the Taiko switch, router, and DC distributor. And since we didn’t need a phono stage either, that freed up another shelf—allowing us to separate the Olympus and I/O instead of stacking them (another improvement).
The difference these HifiStay racks made is crazy. If you separate the Olympus and I/O with these racks, you’ll never want to go back to stacking. And you may, just like us, decide you don't need your turntable (just kidding :)... well, kind of :)... ).
And stacking sounds pretty darn good—but you just don’t know what you’re missing until you try it.
I have been playing with one of there stands in my room too:
So far I have been impressed with HiFiStay and Critical Mass Systems. And not so impressed with a dozen or so other products I have tried recently.
Mine is stacked on Critical Mass Systems but the platform I use was built special for me by Joe Lavrencik to tolerate the weight load of the O/IO stacked
Have you looked into Wellfloat?
Reactions: l3uzz
Vassil, just for another data point, I've been happy so far with my new O-I/O on the top 2 shelves of my ancient but still quite satisfactory Grand Prix Audio Monaco rack, with the carbon fiber shelves and Apex footers (always experimenting with equipment footers and dampers between shelves). I've got one rack in each corner of the room and they provide nice access from the back for cable swaps, etc.
Lots of Olympuses in Dallas!
Olympi-os ;)
Last one @dminches...
Scott Walker in the Dardanelle room (SouthWest Audio Fest 2025) playing Taiko Olympus to MSB Cascade DAC.
They were initially using the USB output from the Olympus into their MSB Cascade DAC (via the MSB Pro ISL).
I brought along an MSB XDMI daughter card and quickly installed it for them.
This was a massive improvement - even with zero burn-in time, the XDMI MSB Pro card was a clear upgrade.
MSB Cascade owners likely have no idea how much performance they're leaving on the table without pairing it with an Olympus MSB XDMI.
A reel to reel and Olympus server. What else could someone ask for?
Any reason for no shelves under the Olympus/I/O?
This is actually the recommended way to use these stands. The shelves are optional and only needed if you can’t position your components directly on the stand. For example, I use a shelf to hold my router, switch, DC distributor, and LPS all together.
The stand has four integrated feet on each level - HiFiStay calls them PerfectPoint. You can move them around to sit exactly where your component needs support. You can also level each one if needed.
Not required, but HiFiStay also sent these to try out:
They replace the stock feet of the Olympus/I/O and sit nicely on top of the PerfectPoints.
This is the end result:
Thanks. I bought a set of demos from Oz, but it was never clear to me that the shelves weren’t the preferred use-case.
HIFISTAY Mythology Transform X-frame (TXf) equipment racks were originally developed under boardless concept. However, optional boards can help to accommodate certain electronics / gears that need a board / a shelf (e.g. turntables with separated motors or PSUs and two small electronics on a same shelf etc.).
Hi Emile,
Is UPnP still on the table? I am not a Roon user.
Hi @adyc ,
Sorry for the late reply, I just noticed I missed your post.
Yes, we actually already have it running. You will be able to use it with already existing controllers like bubble upnp or jplay ios, but we’re also adding player functionality to the BMS app. The BMS app will evolve into a multiple functionality Taiko app which can manage multiple Taiko technologies, like bms, music playback, xdmi settings, dac settings, configure/update/troubleshoot your router and olympus and/or extreme.
Although it’s operational, I cannot give you an eta on it’s actual release.
Note this particular playback software development is not related to the XDMS software project in any way, it runs in parallel / on a different track, although it will work with USB devices, it’s primarily developed to work directly with the XDMI protocols (and yes XDMI is coming for the Extreme product line).
I do have some “beta” screenshots I can share, there won’t be a alpha/beta program, it will just be released as an update.
This was mailed out, next to each person for week 1 and week 2 having been contacted individually.
*Production Schedule Update*
Here’s a quick update on our production schedule:
Orders assigned to Week 1 (Mar 17–21) and Week 2 (Mar 24–28) are mostly completed. Two units are still in progress:
#80 – I/O is completed; Olympus is still being worked on.
#92 – Still in progress.
Both are expected to be completed and tested early next week. The remaining units are either with the dangerous goods specialists, en route to them, or undergoing final testing.
Emile visited the powder coating facility yesterday. So far, the black powder coating has shown a 100% success rate. That said, issues can still occur due to improper handling or packaging during shipping. The powder-coated chassis Emile reviewed are scheduled to arrive on Monday morning. Once they arrive, we’ll inspect them, assign them to order numbers, and send out an update.
A more detailed update will follow on Tuesday.
