Good questions. Not to dodge, but it is a bit like asking how much speaker toe in is best. I like a lot of toe to get a deep stage with a lot of focus. Most guys (to judge by pictures anyway) have them more straight ahead. I never could understand that, but to each his own.I’d leave the Puritan City Master hooked up too — but I’d try with and without. I’ve got a Puritan Ground Master and was surprised to find it sounds better without it.
As I was listening earlier today, I received the message above from ptman. It motivated me to try the ground box booster on my Puritan Route Master (which connects my preamp, DAC and mono amp) to a Puritan City Master. I compared this to connecting the GBB to my Puritan 156 conditioner (with and without the City Master). I was expecting to have better results with the 156 connection, since power connections typically yield the best results in my system. I was wrong. Connecting the GBB to the Route Master (which is connected to the City Master Ground), sounded the best. Thank you pyman for describing your test results with the QKore.
Maybe the best place to put the Ground Box Booster is wherever you happen to have the most ground noise. Will be interesting to hear where the Ground Box sounds best after things have had time to burn in.Hi Halydean,
I have the main ground on the Puritain Route Master, connected to the Puritan City Master.......which is plugged into the wall.
I also have a Torus AVR that I use as a seperate power conditioner, just for my 2 REL T9x subs.
After experimenting with the Ground Box Booster (only for a few hours), I felt that Krissy's device was best on my Torus ground instead of the Puritan 156 or Route Master.
I have an old Entreq Silver Telus that I tried on the Puritan Route Master for the first time, and was pleasantly surprised by the result even with a simple ground cable versus the expensive Entreq Apollo cable.
Based on forum feedback, the ground box booster really needs a week to break in, so I may put it back on the Puritan Route Master for a full week.
What did you settle on for Holostages on your ethernet switches? I'm curious to know anyone's findings on using them on switches, modem, router, bridge, et al.I am updating my comments with a visual of how I am using my 8 Holostage. I also placed the Heartsound Fuse Box on my fuse box panel about a week ago. Wow!
I previously had all of my Holostage on my Components in my Audio rack, plus one each on my crossovers. After experimenting with different placements, I have come to my nirvana in my system. I kept the two on my crossovers for my Aurora speakers, which are in the corners. I then placed two about 5 feet in front of the speakers, but they are closer together. This may be the key for me as they are only about two feet apart in the middle of the room. Then, I have two behind me on the counter, directly in line with the speakers. Finally I have two up high on top of a cabinet directly pointing to the speakers.
The crossover height is 14", the front table height is 24", the counter behind me is 36" and the cabinet height is 10'.
This produced the best sound for my system. But maybe I might be missing the effect of the Fuse Box that I placed on my fuse panel. Or maybe the combination of both elevated my music. Whatever, everything sounds great.
Long time Miller!
In addition to the many well documented, wonderful improvements the holostages have contributed to the acoustics of the room, I discovered holostages gave the range of my router’s Wi-Fi a huge boost. I no longer have any dead zones in the house. I placed one holo on top of the Verizon FIOS router & attached one to the underside. Router is cylindrical in shape with a diameter slightly larger than holostage itself making it an ideal platform for such an application.What did you settle on for Holostages on your ethernet switches? I'm curious to know anyone's findings on using them on switches, modem, router, bridge, et al.
I followed your advice and the improvements are tremendous. Every aspect of SQ is improved but spaciousness and dynamic ease are the most prominently displayed. Trying to push it farther I added a second Holostage behind me and improvement was slight. What I discovered accidently is that the second unit needs to be next too the first at approximately a 45 degree angle.It then doubles the impact (perhaps more than doubles). I did the same in the front placement and got a vast improvement in center image solidity and organization . 90 degrees does not work! Aware of placebo effect I tried each arrangent several times- consistent and not at all subtle.Have ordered more to do the same on the side placement locations.The impact of Holostages on the listening experience is nothing short of astonishing. Initially, they almost overwhelmed me - placing 12 units across my system, including my router and modem, drastically altered the sound to the point where I barely recognized my setup. It was dark and dull and the soundstage was warped. Each slight repositioning created significant changes to a point it almost drove me crazy. I started removing units locking them far away in another room so they wouldn’t have an effect in the sound. In the end, I stripped down everything and started slowly from scratch.
After hours of trial and error, a clear pattern emerged:
- While placing the elements on components has an effect, their real magic lies in optimizing the room itself. Strategic placement transforms the entire listening environment.
- Each unit subtly pulls the sound toward its location. To maintain coherence, symmetry is essential; otherwise, an uneven placement can warp the soundstage to a disorienting degree.
Placement Strategy (I used nanotape so I can stick them anyplace)
First Step: Place one unit on the front and back wall at the top to expand vertical soundstage height. They must always remain in axis.
Second Step: Place two units on the sidewalls, midway between the speakers and listening position to enhance depth and pull the sound further into the room. Again, they must be in axis.
With these two steps my room „locked in“. From now on, I could place a fifth unit somewhere in the room without the drastic change of result and without the warping effect of the soundstage.
Lowering the height of all four Holostages helps find the optimal balance between body/darker timbre vs. airiness/treble energy. A higher position increases treble energy, stage height and airiness. A lower position increases body/weight, focus/smaller images and will lead to darker timbre. They must always remain in axis and at the same height for best results.
If more weight is needed, Holostages can be placed on top of gear. This increases body, but leading to a darker timbre and smaller images.
Holostages can drastically improve room acoustics and the listening experience by tuning the sound to one’s liking. However, achieving the best results requires a willingness to experiment. In my setup, randomly placing them on components only made things worse - but once properly positioned, the transformation was remarkable. With patience and careful placement, they will increase stage size and depth significantly and will make the music feel more alive than ever before.
By 45 degrees? Kindly clarify.I followed your advice and the improvements are tremendous. Every aspect of SQ is improved but spaciousness and dynamic ease are the most prominently displayed. Trying to push it farther I added a second Holostage behind me and improvement was slight. What I discovered accidently is that the second unit needs to be next too the first at approximately a 45 degree angle.It then doubles the impact (perhaps more than doubles). I did the same in the front placement and got a vast improvement in center image solidity and organization . 90 degrees does not work! Aware of placebo effect I tried each arrangent several times- consistent and not at all subtle.Have ordered more to do the same on the side placement locations.
Meant to include this about holostage & router. They have almost all but eliminated EMF & RF noise emanating from the router when measured with an EMF meter like the 3 in 1 Tesmen.What did you settle on for Holostages on your ethernet switches? I'm curious to know anyone's findings on using them on switches, modem, router, bridge, et al.
/---- Bottom of one laying on top edge of the other. Don't ask me why but very powerfull. Other conformations I tried maybe a BIT better than one.By 45 degrees? Kindly clarify.
Thanks, Jeff. How do you organize them in a 45 degree angle? Just the front and back one? Can you please send a sketch or a picture?I followed your advice and the improvements are tremendous. Every aspect of SQ is improved but spaciousness and dynamic ease are the most prominently displayed. Trying to push it farther I added a second Holostage behind me and improvement was slight. What I discovered accidently is that the second unit needs to be next too the first at approximately a 45 degree angle.It then doubles the impact (perhaps more than doubles). I did the same in the front placement and got a vast improvement in center image solidity and organization . 90 degrees does not work! Aware of placebo effect I tried each arrangent several times- consistent and not at all subtle.Have ordered more to do the same on the side placement locations.
/---- Is my sketch. You lay one flat and lean the other one with it's inderside on the upper edge of the first one. They are next to one another but one is at about a 45 degree angle. BTW it is causing the room(?) to break in. Wonderful at first. Second day elevated (but tonally beautiful ) highs and no mid bas. Third day kind of fractured and fuzzy sounding. Day four absolutely awesome, there is not an aspect of SQ that is not vastly improved. I don't expect anyone to believe this until they hear it. IT IS NOT SUBTLE, at veast not here. Awaiting more so I can do this in side locations.Thanks, Jeff. How do you organize them in a 45 degree angle? Just the front and back one? Can you please send a sketch or a picture?
