The Grid Protector, the EMI Protector and The Allocator By Schnerzinger-In My System and I’m Blown Away
The point of me posting this was not to get into a debate with you or anyone else over effectiveness of the different approaches.
Shunyata is known for its no-BS approach to product communication and it’s an engineering lead company. They sell these to hospitals where they improve imaging, for example.
You are making incorrect assumptions, by assuming that QR-BB “must” be a capacitor, and with the low/high pass filter stuff. It’s not how these devices work.
There is no one best approach. You’re not going to cancel all noise nor are you going to filter all noise - that’s why I think tackling the problem from both ends is best.
Reactions: Steve williams
It will be definitely very interesting to see how the AudioQuest Niagara 5000 compares to the. Allucator. Though like Shunyata or the Gryphon Powerzone - every power conditioner or however it's gonna be called has its approach.
The good thing is that the Schnerzinger outlet, power grid and EMI protector all work independently- and any further add on like Multiguards or Allucator or their fuses will be exciting to see how they change/improve things.
What I still don't understand is how the Power Grid Protector can work a whole year just by being connected 15min to power once a year?!
Reactions: Zeotrope
Sorry, bad choice of words on my part.
The big advantages of Shunyata AC distributors are:
1) Blocking noise generated by components. Components generate noise and put it back into the AC line, it's not just external noise that needs to be eliminated.
2) Additional current delivery
3) Noise absorption:
The NIC™ (Noise Isolation Chamber) is a patented technology that reduces high frequency power line noise.
NICs™ use a non-reactive ferroelectric substance that actually absorbs high frequency noise. This reduces noise without any of the negatives associated with power filter coils, capacitors and transformers.
Yes, it's marketing; but I don't think it's exaggerated.
I agree with what you say but IMO and its only an opinion but based on having grid, EMI and Allocator in my system I’ve found that the synergy is not 1+1=2 but rather 1+1>2. My point is that I feel you are indeed reaping benefits but I tend to agree with the post above which postulated result “ might” be even better when you go all Schnerzinger. It’s a system with a contribution made by every one of their products
Reactions: jasond and 57Uli
The GRID comes with a dedicated AC PC and a wall wart. It’s the latter to which they refer
Reactions: 57Uli
But they recommend the use of the Power Grid without connecting the power cord - right? It's just difficult to get how a component with no power connection for a year can work energy wise? :) Because the Power Grid should be active 24/7 and that is also quite energy consuming. So the best battery etc. would be empty after a short while.
Fully agree.
Indeed, once a year for 15 min…! It’s obviously charging a battery, or a capacitor :eek:. It obviously doesn’t use much power.
Of course, when set to positions I and II, they use continuous 12V power… or perhaps not continuous but more frequent than 15 min per year.
I would love to open one up (but I won’t, they seem well sealed).
Interesting side note:
EMI is the appropriate term for low frequency noise, less than approximately 20 kHz, and RFI is the appropriate term for high frequency electrical noise, greater than 20 kHz.
Wifi for example is on 2.4 GHz and 5 GHz.
I have a small temp sensor (Govee) that broadcasts on Wifi and uses a small 12V 23A cell battery. It lasts about 2 years. So, it does make sense. I’m sure a battery this size would be fully charged in 15 min., as an example.
Good point. I have mine on 24x7
Reactions: aangen
(...) Interesting side note:
Just a small clarification.
EMI is general electromagnetic interference, RFI is radio frequency interference. RFI is a specific type of EMI. Due to the usual mechanisms of interference, we usually associated EMI to frequencies up to the Very Low Frequency (VLF) 30 KHz and RFI from there to Terahertz (THz) Band.
However switching supplies and digital electronics made the situation more confusing. When addressing interference in specific terms we should refer the bandwidth. :eek:
We must remember that usually this type of sensors only emit for a few milliseconds occasionally - once per minute or less for example. The duty cycle is very low.
Very interesting, thank you.
Indeed, Schnerzinger recommends power level "0" and not connecting the AC 'wall warts' to the units.
EMI Manual:
"Usually the setting is now complete.
But if the base setting is not sufficient for the present interference field spectrum, the permanent connection of the 12V power supply to the grid is required. It should be connected to a power circuit separate from the HiFi system – ideally even to a different power phase."
If I had outlets on a different circuit and could plug them in without making the cords look too ugly, I would try it at Power levels I and II; but I am happy with it at 0.
The info from @microstrip helps illuminate why it can run on battery power for a year.
Micro is the forum expert on electricity. It has been refreshing to see him posting more often.
Since I added the MULTI GUARDS a resetting of GRID and EMI was beneficial IME.
I was using them set to I or II before. I liked them so much more set like that.
Now they are set to 0. It means no wall warts plugged in.
Same realism but much more accuracy in tonal balance and instrument timber especially in low region. The overall improvement is a more convincing representation, coherent and pleasant at the same time.
I’ll illustrate the point with many recent installs. In practically all cases where the clients have a Grid/EMI only - and selected given settings and were happy, introducing an Allocator and Multiguards forced a reevaluation of those initial settings, but never a drastic one. With the noise floor dropping even further and greater delicacy and refinement, it’s tempting to manifest the greater potential even further, especially if Schnerzinger wires are introduced. But the final settings adjustment remain.
Inside is a small Mickey Mouse figure, with his middle finger extended.
Reactions: MarkusBarkus
Reactions: jbrrp1 and aangen
Gideon from Audioarts came today to select settings on my Grid/EMI and we spent time locking in with my new addition Zellaton's (replacing Wilson's). He wanted the Z's to break in before returning to choose final settings with me. He asked me to be patient with the system breaking in which was a tough wait ;) But so glad I waited because the air, dimension, soundscape and midrange came out of nowhere today and it's just too crazy to even describe. It was actually scary the way the entire system changed and I can't explain how these things work. I'm taking off from work tomorrow !! Will post pics soon !!
Hi Gin
can you share your settings on both
Hi Gin
I strongly recommend to decide for settings individually. It’s totally depending on the own situation what sounds best and more switches engaged is not necessarily better (if a switch makes no clear improvement, its better to leave it off). My good experience is to take a piece with bass that’s critical. between loose and tight, something like a classical chamber orchestra piece with focus on separation and depth/3D, a piece with a magically enveloping voice and a piece with a.very top end open sound and air. With the right setting all should be on best level at the same time and certainly better than without the unit (cross check at the end). You certainly are aware, I just say so because we all sometimes tend to be lazy or cheat ourselves.
Reactions: 57Uli
I totally agree. I was merely curious as to settings. I have had lengthy talks with Gideon about set up methods and then coming back after system burn is such as new speakers by Gin
Of note, Gideon knows very well the speakers I had as well as my electronics. Based on that knowledge he suggested what settings I should use to derive best effect. Gideon will be sending me a pair of Zellaton Plural Evos at the end of March until my Zellaton Reference Ultra speakers arrive. He will be flying in to help set up the Plural Evos and willat the same time reset my Grid and EMI Protectors. Those settings almost certainly will change once my new speakers land and change even more once the speakers settle.
I have discussed in detail with Gideon how he goes about the setup process which I find veryinteresting. Two boxes with 3 switches each with three positions create 729 different combinations (3x3 x3 =27 x 27= 729)
so its not all about lazy but all about exploring each possible combination
The one thing I gleaned from Gideon is to always start. with the Grid first and once settings are determined then you plug in the EMI and begin again
Reactions: jasond
Just to make things more complicated: the devices placement counts, too.
I ended up placing the EMI (elevated around 60 cm from the floor) EXACTLY CENTERED on the front wall, behind the speakers.
I also noticed an improvement placing the Master in the middle of the room, I mean at the same distance from the 4 MULTI GUARDS which are plugged into 4 different sockets (2 of the front wall and 2 of the Allocator on the side wall).
