The electrical gremlin situation that you speak of for this particular unit is not typical of many other Io owners. I have had my unit for 20 years without any problems. There are others in the forum with the same phono stage that have also have owned their units for many years without issues too. A forum is really not a full representation, only a partial representation, of other owners who own Io equipment. Therefore, it is not an accurate assumption about failure rates.Reading stories about persistent maintenance problems with tube gear makes my blood boil. There is simply no reason for properly designed tube equipment to have failures like those reported in this thread. A phono preamp should be just as reliable as a solid state unit and it should require no maintenance other than occasional tube replacement every several years. Furthermore, in the rare instance where something does go wrong, it should be easily repairable. I.e. no solid state garbage that becomes obsolete after five years.
My all-tube phono preamp is my own design and it has been problem-free for over 15 years. It also happens to sound great. Of course, you can’t buy my unit but you can buy a very similar commercial offering—-the EMIA phono stage called the LR Phono Corrector.
I do agree that equipment should last. My Soundcraftsman, Carver, DBX, and SAE equipment form my younger audio years lasted forever and made future owners happy. Equipment can be made to last a long time so long as it is built to a standard. The fact that you built your own tube equipment meant that you could take the time to ensure longevity through precise quality control and sourcing internal components that are high quality and have reliable and extended performance over a longer period of time than a normal mass produced device.
Many older U.S. made mainstream audio equipment in the late 70s and early 80s were built to MILSPEC (military specifications) standard for quality and longevity. The type of equipment that is made to this standard or absolute state of art should last a long time before MTBF (mean time before failure ). Every once in a while you get a bad apple. If 2000 Io’s were built and only 10 failed over a 2 year period, this would only be a .5 failure rate over a two year period. That is not too bad.
Do you have any technical specifications of your product? Any reviews?
