I wonder if you (and Leif) had bad luck, or used the Io in not-so-good ways (before rituals). Like keeping it on and running hot for longer periods (like I did). I ran Io mk2 for ten years, and upgraded to eclipse, before having a serious problem. But then, it was not easily diagnosed, and I had to ship all three boxes across the atlantic....and wait a long time. Aesthetix told me that the error was hard to identify, and in the end they had to replace both volume controls and some other components (not power supply). Yet they made the repair for a very reasonable price. It has now worked well for six years. So in my case, at least, "crappy quality" is not a fair judgement.
What is more relevant for me, is if Aesthetix will cooperate with a local technician, the next time some problem appears. Like Kcin mentions "a good tech can leakage test the transformers with the right instrument". Its been a long time since I've opened the power supplies, since I have not had problems pointing that way. But I wonder, how can I identify the need for tube change, in the p-s, does the sound get more muffled, or what. The tubes are 'stock' from Aesthetix 2018 I think. I am using NOS in the control unit, esp v1-v2 position, but have not experimented with NOS in the p-s.
My "remedy" - like before - is to use it sparingly, not let it get too hot, and when problems show up, get a replacement, so you can still play your records. This was actually an interesting experience, for me, when the Io was away for major repair for a long time. I first bought a very cheap Chinese Riia, that sounded very bad. Next, a used Graham Slee Fanfare 3 phono stage, for ca 200 usd. Not so bad. And finally, ASR mini basis mk2 (800 usd used) that sounded quite OK, and - interestingly - had some of the same sound philosophy as the Io. So I've kept the ASR, like a plaster on the wound if Io goes to repair. However, I have to mention, I was amazed when the Io came back, after more than a year. It viped the floor, including the ASR. A HUGE difference, in my system. The ASR sounded quite good, it was on the right track, but very anemic, lacking dynamics and muscle, in comparison. This experience made the central importance of the phono stage startlingly clear to me.
Hi OGH,Hi Kcin, I just joked about rituals. I just turn my Io on, when needed. Based on the LOFO rule regarding the amps - last on, first off.
So, turning the system on, I start with the Io, next the preamp, and then the amps.
I will check what el34 tubes I have in the p-s. I would guess that transformer problems would often be audible (strong hum?) before any breakdown. I have no complaints so far. Although my first power supply (from ca 2002) has a bit more hum that the second one (from ca 2012). None of this is audible from the listener position. Or just very little. I think it is drowned by the general noise floor, made by all sorts of gremlins, like the needle tracking the music but also getting the noise from the vinyl, and whatever.
Some listeners find that the noise floor is anyway too high, with the Io. I don't agree. Maybe they just need to get the right system match - a robust MC cart with ca 0.5 output or so, correctly adjusted. And then, selected ultra low noise tubes especially in the first gain stage. Maybe the latest Io is low noise with carts down to 0.3 or even 0.2, I have not tried.
Hi Ron
"Shockingly quiet" - I am impressed. Although thinking also, not overdo this, we are listening to music, not quiet. What is your comparison? An earlier Eclipse version?
This is exactly how I feel. The only exception is that the V1/V2 stages seem to give up the ghost sooner than the other positions. Specifically, I have noticed a low-level whistle coming from the Io in the V1/V2 after prolonged use. My solution is to swap out the tubes for Sovtek 12AX7LPS. These were the tubes in the Io V1/V2 stages in its original form back in 2005 when I purchased it brand new. Works great. Perhaps, I should reach out to Glen for a replacement set for the V1/V2. Aesthetix spends considerable amount of time matching tubes for each unit.My new Io Eclipse is shockingly quiet for a tube phono stage.
I could not find any fancy, expensive NOS tubes nearly as quiet as Jim White's stock tubes. I abandoned my tube swapping project, at least for the first three gain stages.
Running the equipment 24/7 for a year would put 8,760 hours on the tubes. All tubes in Io would essentially be past their prime and needing replacement. 12AX7s are rated for 10,000 hours. The EL-34 are rated for 2,500 hours.Like keeping it on and running hot for longer periods (like I did).
Please see posts earlier in the thread about power supply upgrades that lower the noise floor. The new Aesthetix wound transformers and the new capacitors really make a difference. Same with shielded umbilical cables between the power supplies and the phono stage.I am happy to hear if Aesthetix has improved the Io. Looking forward to your further listening impressions.
So, I opened up one of my power supplies to check out the power supply tubes as I was getting ready to make some tube orders. The power supplies in this one power supply seem to be of the older variant and not the new ones. At least I don’t see or can’t tell if anything has changed. I have a few of the original power supply pics and these look the same to me. This is what I received back from Aesthetix. I will check the second power supply tomorrow to see if that has similar power supplies or something different. I was told I was getting the new power supplies when I made the order to upgrade to partial Eclipse with dual power supplies.The gold capacitors in the phono stage (head unit) are Peter Moncrief's Stealth Capacitors. They are coupling capacitors and contribute to improvements in sound quality.
The power supply capacitors are part of the voltage regulation and filtering. These are the new Panasonic (if I recall) that are the ones we have been attributing the lower noise floor to. This comes from less noise within the capacitor and better filtering of the noise from the voltage regulation. They have the purple or green case color (under all the transformer leads).
@audioquest4life your links don't seem to work for me. The first pic is the old transformers with the varnished coloured core. The second pic is the new transformers that are primarily black. Capacitor changes in the PS and control unit were part of my mod to the new transformers. In the control unit the coupling caps that are gold colour were part of the partial Eclipse mod-- the gold caps are stealth caps and are the primary part of the partial Eclipse mod.So, I opened up one of my power supplies to check out the power supply tubes as I was getting ready to make some tube orders. The power supplies in this one power supply seem to be of the older variant and not the new ones. At least I don’t see or can’t tell if anything has changed. I have a few of the original power supply pics and these look the same to me. This is what I received back from Aesthetix. I will check the second power supply tomorrow to see if that has similar power supplies or something different. I was told I was getting the new power supplies when I made the order to upgrade to partial Eclipse with dual power supplies.
New power supply
View attachment 142660View attachment 142661View attachment 142662View attachment 142663View attachment 142664View attachment 142665View attachment 142666
The 12AX7s are in the voltage regulation, not the rectification. Nit pic aside, the critical aspect is low noise and low microphony. The quieter, the better. I often run tubes in the phono stage for a couple years, then move them to the power supply.Tubes in power supplies? My two power supplies have two different sets of 12AX7 tubes. My older power supply has Tung Sol 12AX7 and the newer power supply that I added has JJ 12AX7 tubes. Being that there are six in each power supply, would having different sets of tubes in each power supply negatively affect the sound qualities of the music? I am thinking maybe not as the tubes in the power supplies are not signal related, only part of the voltage rectification circuits. Anyone know otherwise? I do plan on matching the tubes as I don’t want to have any tube mismatches in any of the circuits, power or signal. Maybe I am a little OCD about matching tubes.
These are the original transformers, not the new Aesthetix in house ones.So, I opened up one of my power supplies to check out the power supply tubes as I was getting ready to make some tube orders. The power supplies in this one power supply seem to be of the older variant and not the new ones. At least I don’t see or can’t tell if anything has changed. I have a few of the original power supply pics and these look the same to me. This is what I received back from Aesthetix. I will check the second power supply tomorrow to see if that has similar power supplies or something different. I was told I was getting the new power supplies when I made the order to upgrade to partial Eclipse with dual power supplies.
New power supply
View attachment 142660View attachment 142661View attachment 142662View attachment 142663View attachment 142664View attachment 142665View attachment 142666View attachment 142685View attachment 142686View attachment 142687View attachment 142688View attachment 142689
