Well i ll just stay with optimal/good conductivity , and optimal isolation then(teflon), i m definetively not gonna spend $$$ on it .
1. there are so many superior cables and superior techniques , that logic is totally out of whack.
2. There is no real value as second hand prices drop like a stone .
3 . with that amount of money there are real improvements to be made elsewhere.
As soon as i have my new speakers ready the importer of lamm in holland is gonna come over for a listen , but he insisted he d install Jena labs as well as he imports them also, so we will see
Just out of curiosity what constitutes optimal isolation withTeflon do you recommend since it comes in umpteen grades? And a grade that might be good for one application might not work in another. For example, having all the polymers having a high degree of alignment might be good for one thing but not say for signal transfer where that alignment might cause the cable/cap to hold onto the signal. Or in the case say even of polystyrene (used in caps), you need polymer alignment if optical clarity is your goal; if cap discharge is, you want a more randomly oriented plastic.
