Most Accurate Stylus Force Gauge?
I'm using a pocket-scale from German manufacturer Kern, capacity 60 g, readability 0.01 g, comes with 50 g brass calibration weight . For adjusting tracking force I remove the armrest, place the scale such that the top of the weight is at record level, lower the arm onto the weight, see pic. With 60 g weighing capacity I can use the scale for other tasks.
Klaus
But please make the measurements with the tip of the needle, not with cartridge body or anything else, as you get other/false results.
Of course, but for the pic I didn't want to place the stylus tip itself. Btw, price for the scale is € 81 ex. VAT (85 USD).
Klaus
I seem to like the....
Riverstone Audio Record-Level Turntable Stylus Tracking Force Gauge/Scale, 0.005g Resolution, Measures VTF at Correct LP "Record Level" Height (2 mm to 3 mm)​
Add copy shown below....
About this item
  • A Professional digital tracking force gauge designed for vinyl record purist's interested in precise measurement of vertical tracking force (VTF) at the correct vertical tracking angle (VTA). When used with the detachable cantilevered extension arm, the gauge closely approximates the vertical position of the stylus on the surface of a vinyl record when it is playing on a turntable- providing accurate “record-level” measurements of tracking force.
  • For optimal accuracy, tracking force should be measured at the same vertical position as the record surface. With Riverstone's VTF gauge's patented design (US Patent D878232), tracking force is measured 2 mm - 3 mm from the surface of a turntable mat - the height of a stylus tip resting on an LP record (LP's have a thickness range of 1.9 - 2.9 mm). With less expensive gauges, the measurement distance is typically 6 mm to 9 mm.
  • Precision strain gauge sensor provides 0.005 g measurement resolution and accurate measurements over the entire calibration range of the VTF gauge. To ensure accurate VTF measurement, our VTF gauges undergo a rigorous multi-point calibration procedure to verify the linearity, repeatability and accuracy of the VTF measurement. We have confidence in our gauges and provide TWO calibration masses (5g and 20g) to verify the readings at any time and also allow for future re-calibration if needed.
  • Manufactured using non-magnetic materials to minimize interactions with MM and MC cartridges. The housing of the VTF gauge is manufactured from a durable plastic. The cantilevered extension arm is made from a non-ferromagnetic grade stainless steel and the locking screw of the extension arm is made from brass. A polymer pad protects the stylus tip and allows stylus centering on the measurement platform.
  • Riverstone Audio Tracking Force Gauges are covered by our no-nonsense THREE-YEAR WARRANTY. The gauge is designed with two levels of battery protection, including auto-turnoff of the display and automatically powering off of the circuit after 60 to 120 seconds of inactivity. A detailed instruction manual (in English) is provided. Includes a tin storage box to protect the VTF gauge when not in use. PLEASE NOTE: *****Requires one AAA ALKALINE battery (SORRY, BATTERY IS NOT INCLUDED)*****
Can be bought on Am'zon for as little as $33.50 with free shipping.
Best wishes,
Don
This was so inexpensive, I couldn’t resist buying one just for fun.
I unboxed it and checked it with my calibration weights this afternoon.
Here are some photos.
Calibration at 1 gram, 2 grams, and 3 grams were perfect.
This is the exact scale I use. Cheap and accurate. I basically use it to confirm that the sliding scale on my SME tone arm is more or less accurate and nothing more. I adjust VTF by listening to slight changes. I don’t care what the exact number is. Accuracy is not important for my purposes. I just don’t want to do damage to the cartridge by being way off some number. The scale on the tone arm is perfectly fine and that’s what I record in my notebook. When I return to that cartridge at some later time, I adjust by listening again making tiny adjustments, but always starting in the right ballpark.
Some cheap general purpose balances bought at eBay or AliExpress are made of ferrous materials, not aluminium. They can violently attract the cartridge when we lower it ... Check with a magnet before using them.
Or the ferrous plater of the original Thorens TD124. Even with the aluminium platter and mat it would affect the tracking force of some moving coils.
Not everyone can handle a td124...you have to do an apprenticeship:p20250102_173136.jpg20250102_172901.jpg
Surely - but fortunately the 124 II had a non ferrous platter. The TD124 was an excellent platform for experimenting and tuning, in stock form it had several problems.
BTW., the interference effect is strongly dependent on cartridge type.
That was the first modification to remove the quick start platter and replace it, but not because of the magnetic behavior but because of the sound. In France there is a company that demagnetizes the platter for information for others.
pom with the green cast platter sounds really good, today many manufacturers make a platter out of two different materials.second avantage is no magnetism influnence.
Reactions: Argonaut
I bought the Riverside gauge and have found it to be as accurate as the Ortofon DS-3 at a fraction of the cost.
Too bad they don't sell to the UK.
