Hi FactenWondering if any members have tried this tube and will offer impressions on its sound and reliability
Hi Kende,Hi Facten
I have the same amp LM518 like you. I have the Linlai 845DG tube in it , much better then Psvane T mark2 or the Psvane replica WE.
Also I have changed the rectifier Amperex (NOS Holland made 5ar4) to Linlai Elite 274B molybdeum plate. The rectifier gave me audible effect, more tide bass , cleaner subtle nuances. 1 1/2 year since I have them(845,274B) no problem . Comparing DG to what I had is like I would take off the blanket from music. I do not have experience with 845D Linlai , but I heard the 845 Elite molybdeum plate and Elrog . In terms of sound nuances is close to Elroge at least for me. It was different amp and source. I am satisfied with the 845 DG Linlai. Sorry No experience with 845D linlai. I just shared my impression with some Linlai tubes.
Hi Kende,Hi jmaktai
The Linlai E 845 is the best from line , comparing to Psvane Acme 845 are the same level but different in sound character , assuming because of molybdenum plate .The 845 Elite according to someone is like the sunrise refreshing , the Psvane like sunset lots of micro detail ,nuances . I do not have the Elit 845 but i have heard in one friend system ,it is better comparing to DG in nuances micro details but depend of system , it might be to analytical with cd player . The difference might be not so big comparing to DG . If my budget would not be issue I would chose Elite. ...or Psvane Acme but acme had lot of issue of red plating. I am happy with DG. Sorry i do not have experiences in my system.
Regards.
Thanks Kende for your sharing your experiences. I'll report back once I've had everything in place.Hi jmaktai
Since your driving tubes will be 300 b I am assuming will go well with 845 Elite , because the driving tubes can have effect on the sound too , at least in my case . I have a Line Magnetic 518IA , set . when I changed the driving tube from the stock one with 7581a tung sol the clarity and tighter bass was audible.Also the preamp tubes can tailor the sound. If budget no problem I would go with 845 Elite. My next purchase will be the Elite .
I have an old 40 year Sony CDP 333 ESD player modified NOS (not over sampling) and with tube output 6N2P -EB rusian tubes. The dac side has the Philips TDA 1541 chip. Because all the mods done is closer to analog sound . The speakers are Full range coaxial 2 way , Coherent audio gr 10 , 94db 8ohms.(Canadian made) . I bought the linlai from trusted seller , no issue since and fast and safe shipping and good price too. Some site states that on Linlai Global site the tubes are for European market and different than the rest of Linlai Elite without the logo Global. I think is just marketing BS. The price also is better on this site . You will decide . I send you the website .https://www.hifi-amplifiers.com/en/linlai-electronic-tube-valve-c-131/ Good luck and enjoy the amp. Do not judge to early the tubes. They need at least 200 hours to burn in.
Regards.
Yes he makes both the Khozmo and Hattor Audio products.Hi
The line Magnetic preamp section it is not realy bypass the signal tubes, you can use passive or active preamp but the signal still goes trough the tubes.Mine has the Alp velvet ,i do not know if is the blue. My amp has no more warranty because i did some capacitor change in the signal path. i replaced the mundorf caps ,with jupiter cooper , and duelund cast pio . regarding the preamp ,yes I have in plan to use passive preamp from Arik but the cheaper line the Khozmo. Arik allready gave me a cote. Get in contact with Arik and give him all the info regarding the amplifier , speaker and cd player impendance so on. He can tailor the preamp to be the best as possible to mach the system .He recommended the best option.Khozmo and Hathor has good reviews.Khozmo and Hathor is made by the same guy Arek. .https://positive-feedback.com/reviews/hardware-reviews/khozmo-acoustic-passive-preamplifier/
The Khozmo 'Shunt Relay' Passive Preamplifier - Review
The Khozmo 'Shunt Relay' Passive preamplifier delivers audio for those who want the purist of audio. Handmade and Built with sound as the priority.www.tannoyista.com
Hi Kingrex, you mean 845 tubes?I have to check which one I have. It was about $1000 a pair. I don't like them much.
Thanks Kingrex. I re-read the massive "Psvane Acme Series (new flagship series)" thread in which you were a great contributor in the discussions. It seems you had Psvane Acme 845 which you liked (but returned shortly after you noticed the red plating issue), then Linlai Elite E-845 (which eventually also rep plated), and then Elrog 845 (which also red plated and there was some back and forth between you and Thomas that maybe your amp specced hotter than other amps was the culprit). From your impressions in the thread, I recall you mentioned that Psvane Acme has more flesh, richer, and thicker tone than the Linlai E-845, which is also something that I think I'd like to have in my system too.I have Lin lai 845 tubes. That's all I know. I don't have access at the moment to look at the specific model.
