Triode Lab 2A3M-II RS GT. The bass sounds of great quality, but I cannot confirm the extension and energy down belowWhich amps?
I've provided tips for optimizing SET performance; as well if you don't understand the weaknesses of the technology you won't get the most out of it.It is a shame that despite a lot of valuable knowledge and experience shared on this forum, much beyond what I could contribute, it seems that there are some killjoys whose focus isn't upon optimizing the performance of SETs
Per my post below, if I biamped the speaker and put the 845 to just the 10" coax, the 845 would probably play with more air and space. Less wool. I doubt it would speed up much. My reference is incredible fast and clean.I've provided tips for optimizing SET performance; as well if you don't understand the weaknesses of the technology you won't get the most out of it.
Any good 15" driver can go to 800Hz. So 250 - 450Hz should be no worries.Per my post below, if I biamped the speaker and put the 845 to just the 10" coax, the 845 would probably play with more air and space. Less wool. I doubt it would speed up much. My reference is incredible fast and clean.
Biamping would be crossing the coax around 250htz to 450htz. That's roughly where it is now. The 15".drivers do a lot of work.
You might want to put this in your thread of 'I'm tired of failing amps'...Been letting the amp play. As you get use to it, its very pleasant and easy to listen too. Take off the audiophile hat and it becomes a enjoyable amp. BUT. Stupid volume on the front pops sometimes. It has a stepped volume attenuator. I think the signal goes through it, then into the signal tube. Well, I changed the pre tube to a very nice Telefunken E88CC that cost about $350 per tube. Stupid amp may have popped a couple times it popped really loud, Now the tube is microphonic. I'm pissed. I;m wondering if there is any way to get into the attenuator and spray deox or something to stop it, I don't want to risk any other tubes.
I've found pops and scratch on attenuators can come from leaky capacitors upstream which allow DC to be on the contacts.A stepped attenuator can make a popping sound when you adjust it if there is even a slight Voltage on the control. That could come from a tube defect and it could come from the source at the input of the amp. Disconnect the source and see if the pop is still there. If the pop only occurs at certain positions of the control, its a bad control.
Yes, better place on the failing amp thread.You might want to put this in your thread of 'I'm tired of failing amps'...
But the nice Telefunken was likely already microphonic. There's no circuit defect that can cause a tube to become microphonic! I'd return that Telefunken if you can.
hmm. This amp was totally rebuild about a year ago. Then it sat in a box for a year. I took it out and it popped with every turn of the volume. Now it is very intermittent and usually at louder volumes. Places where I have not been turning the volume too. I think its dirty. Sat too long and maybe built up some oxidation. Its been in a case in my house in a conditioned space. Not sure why it would happen. I sort of doubt anything is leaking. I will look around.I've found pops and scratch on attenuators can come from leaky capacitors upstream which allow DC to be on the contacts.
It might not be dirt as much as oxidation or contamination from the air (or god forbid, smoking) on the contacts. DeOxit will cure those but go easy on it. The best way to clean contacts like that is to apply with a Q tip and lightly scrub the contacts (if that is possible of course) rather than squirting it in the control. In the old days when contacts were manly type things, technicians used pencil erasers to clean the large contacts.hmm. This amp was totally rebuild about a year ago. Then it sat in a box for a year. I took it out and it popped with every turn of the volume. Now it is very intermittent and usually at louder volumes. Places where I have not been turning the volume too. I think its dirty. Sat too long and maybe built up some oxidation. Its been in a case in my house in a conditioned space. Not sure why it would happen. I sort of doubt anything is leaking. I will look around.
I used pencil erasers on my HO train tracks. I can not get inside the POT. See the Sick of Failing Amplifiers thread. I just posted pictures of the POT. IIt might not be dirt as much as oxidation or contamination from the air (or god forbid, smoking) on the contacts. DeOxit will cure those but go easy on it. The best way to clean contacts like that is to apply with a Q tip and lightly scrub the contacts (if that is possible of course) rather than squirting it in the control. In the old days when contacts were manly type things, technicians used pencil erasers to clean the large contacts.
Then you'll need to go the squirt route. Just work the control well for a couple minutes after applying the cleaner. Also be very careful that you don't dissolve any lubrication on the shaft while squirting cleaner inside. Doing so can not only deposit that lubricant on the contacts, but it can affect the turning feel of the pot.I used pencil erasers on my HO train tracks. I can not get inside the POT. See the Sick of Failing Amplifiers thread. I just posted pictures of the POT. I
Use the Deoxit F5 spray in the green and black and white can. Its the one that leaves a bit of lubricating non-conductive residue. This prevents the contacts being damaged. Any attenuator like this comes with a bit of contact lubricant. Straight on contact cleaner will remove the lubricant and the control will fail in short order.hmm. This amp was totally rebuild about a year ago. Then it sat in a box for a year. I took it out and it popped with every turn of the volume. Now it is very intermittent and usually at louder volumes. Places where I have not been turning the volume too. I think its dirty. Sat too long and maybe built up some oxidation. Its been in a case in my house in a conditioned space. Not sure why it would happen. I sort of doubt anything is leaking. I will look around.
Film caps rarely get leaky unless they are ancient. I run into that sort of thing when I refurbish stuff from the 1950s or earlier. But that shouldn't be happening with any modern stuff. From all this it just sounds like this amp has been sitting around unused too long.I've found pops and scratch on attenuators can come from leaky capacitors upstream which allow DC to be on the contacts.
That is not my schematic. It was an example from DasguteOhrI really don't like that schematic! That 150V can't be riright.
I referring mostly to electrolytics, especially old ones.Film caps rarely get leaky unless they are ancient. I run into that sort of thing when I refurbish stuff from the 1950s or earlier. But that shouldn't be happening with any modern stuff. From all this it just sounds like this amp has been sitting around unused too long.
I really don't like that schematic! That 150V can't be right.
