How long is piece of string? Same relevance as your question.And exactly how long have you been designing - manufacturing & successfully selling your own brand of tube pre amplifiers & power amplifiers...
How long have you been self employed as Ralph’s minister of propaganda ?And exactly how long have you been designing - manufacturing & successfully selling your own brand of tube pre amplifiers & power amplifiers...
I would be interested to know what kind of 8 ohm load that was (8 ohm load resistor or a speaker dummy load with capacitors & coils and resistors). If it was the former, even a poorly designed amplifier can do it. The real problem with set amps is that they amplify to different levels without negative feedback and follow the impedance curve and phase response of the speaker. The poor negative feedback reduces this problem, now it's about finding the right level without it damaging the sound. If you don't want feedback, then you build an RCL element into the speaker that smooths out the impedance curve if the manufacturer hasn't already done that. The disadvantage of this solution is that you lose speaker efficiency. Then you'll hear your set amp amplifying evenly, just as the designer intended.At the very least Ralph is wrong about SETs generating full power down to 20Hz.
The first plot (top left) is the distortion vs. Frequency at different power levels. The Lamm ML2 is rated at 18 watts and this plot shows the distortion at 20hz is essentially the same as at higher frequencies. This amp can produce 18 watts at all frequencies with the same distortion, which indicates a sufficiently large output transformer core with proper winding to allow high frequencies to be maintained. Perhaps Ralph only has experience with inferior designs, which can be compromised.
Ralph made OTLs for 30+ years, which are notoriously load intolerant and bass shy when poorly matched to the speaker. It was so much the case that there was a bit of a cottage industry around autoformers (Spletz for example) to allow them to work better with a lot of speaker types. OTLs are also notoriously low power into tougher loads unless HUGE with dozens of tubes.
The truth is that an amp without negative feedback will have LESS interaction with the loudspeaker than one with negative feedback. This was demonstrated by Matti Otala in the 80s. He found the back EMF from the driver/crossover network can wreak havoc on feedback amplifiers because the feedback creates a conduit that allows back EMF to be pumped back into the input of the amp and reamplified. No feedback means no conduit and no amplification of badly distorted signal coming back from the speaker. Most people don’t realize that the signal comes back…it’s a circuit. Without feedback on a SET that back signal just gets dissipated as heat. Same for any tube amp without feedback. For highly reactive speakers, like electrostatics, this can be so bad it can make a high feedback amp oscillate.
Now he wants to claim Class D is the second coming and basically disavows a lot of what he preached for 30 years. Like negative feedback. He used to tout his amps didn’t use any and now he slags SETs because they don’t use it.
Finally, he fundamentally doesn’t understand or deliberately misinterprets psychoacoustic findings to try to make it fit his amp topology of choice.
Agreed. From what I've seen this forum has definitely become more abusive over the last 18 months.Gentlemen, please stop. We are better than this.
Tom
Most speakers that have suitable sensitivity for SETs will also usually be relatively mild in terms of impedance and therefore frequency response errors...a very minor problem and less than most speakers base response anyway. I would never put such a network in front of my high sensitivity speaker. My Hornings work amazingly well with as little as a 3.5 watt 2A3 amp...no need for help and they are only horn in the bass (DTQWT). Same thing with my Odeons and my DIY horn speakers.I would be interested to know what kind of 8 ohm load that was (8 ohm load resistor or a speaker dummy load with capacitors & coils and resistors). If it was the former, even a poorly designed amplifier can do it. The real problem with set amps is that they amplify to different levels without negative feedback and follow the impedance curve and phase response of the speaker. The poor negative feedback reduces this problem, now it's about finding the right level without it damaging the sound. If you don't want feedback, then you build an RCL element into the speaker that smooths out the impedance curve if the manufacturer hasn't already done that. The disadvantage of this solution is that you lose speaker efficiency. Then you'll hear your set amp amplifying evenly, just as the designer intended.
Exsample real world impedancedummy load of a speakerView attachment 138627
Class A2 is when the grid of the output triode is driven positive voltage. Normally it is biased negative and the driver stage drives it progressively closer to 0V. Driving it positive gives significantly more power but it also generates significantly more distortion. I would think of it more as a reserve tank for large peaks where increased distortion would be less audible.Hi team - I have two technical questions I am hoping you can explain to me in a way that is easy for a realtively bright but electrically ignorant audophile to understand.
First is what differentiates Class A2 from Class A. I understand what Class A is and therefore why when I hear a Class A amp (or one heavily biassed to Class A) I tend to like it. But I am not sure what differentiates Class A2 from pure Class A.
Second is why would an SET power amp use an XLR input (with a transformer immediately behind it). As a follow up to that, to what extent to RCA-XLR adapters degrade things? I don't have any balanced outputs in my signal chain so I know there is nothing to be gained there by switching to a dedicated XLR cable.
A1 means the control grid is always negative wrt the cathode. No significant grid current flows. A2 means the grid can be driven positive for some part of the duty cycle and grid current will flow while it is positive. A2 can give much more power than A1. The input impedance drops dramatically from, say, 1 meg when the grid is negative to less than 1k when it is positive. It acts like a diode.Hi team - I have two technical questions I am hoping you can explain to me in a way that is easy for a realtively bright but electrically ignorant audophile to understand.
+1Most speakers that have suitable sensitivity for SETs will also usually be relatively mild in terms of impedance and therefore frequency response errors...a very minor problem and less than most speakers base response anyway. I would never put such a network in front of my high sensitivity speaker. My Hornings work amazingly well with as little as a 3.5 watt 2A3 amp...no need for help and they are only horn in the bass (DTQWT). Same thing with my Odeons and my DIY horn speakers.
Better bass? what tube have you used with Cary 2a3? I found many of 6sn7 variant design is lacking volume in bass. It does go deep but just lack of the punch. I got few 2a3 SET amps. One with Tango XE-20s using interstage NC-15 with 12bh7, 12ax7 input and One with Tamura F2007 output transformers using 6v6 triode strapped and 6922 input. The best result I got out of these 2a3 SETs is with JJ 2a3-40 tube. It is basically a 2.5V version of a 300B tube. What is interesting is that they sound better than the JJ 300B in a same amp I have with switchable output tube.I used Cary Audio 2a3 monoblocks for the mids and highs of my DIY horn speakers for about ten years then replaced them with a pair of First Watt F3 single ended single gain stage SS stereo amps with JFET output transistors. I like the SQ of the F3s better.
My Silvercore amp with interstage transformer has huge punch from a 2A3 amp. The input tube is a 6C45P, which is a darn good sounding tube.Better bass? what tube have you used with Cary 2a3? I found many of 6sn7 variant design is lacking volume in bass. It does go deep but just lack of the punch. I got few 2a3 SET amps. One with Tango XE-20s using interstage NC-15 with 12bh7, 12ax7 input and One with Tamura F2007 output transformers using 6v6 triode strapped and 6922 input. The best result I got out of these 2a3 SETs is with JJ 2a3-40 tube. It is basically a 2.5V version of a 300B tube. What is interesting is that they sound better than the JJ 300B in a same amp I have with switchable output tube.
It's an old one...they no longer make it. Nice design though with tube rectifier, choke filtering and all non-electrolytic caps. It is 6C45Pi tube with interstage transformer coupling to 2A3 output. All transformers and chokes are from Silvercore.Ooh which Silvercore amp is that? I didn't know he made one with a 2A3 output tube
Apparently morricab can't see what is on the page at the link. The plots do not show the bandwidth of the amp at full power (which seems to be about 15-16 Watts). How it works is that as you increase the output power at low frequencies, the lack of inductance in the output transformer starts to look like a short to the power tube so output drops off. If you measure the primary winding resistance, you can see how this is so. Its usually just a few hundred Ohms, while the load impedance needed for the tube to make power is usually several thousand Ohms.At the very least Ralph is wrong about SETs generating full power down to 20Hz.
Your prior statement you 'don't care' is contradicted by your continued attacks; its obvious to anyone you do care else you would not continue posting. I've found that when someone contradicts themselves in this manner, the comments are never relevent to the thread itself.So Formulaic … So Wearisome … Does this usually work for you Ralph ?
It is all about the match isn't it! I agree that with the proper speakers a quality SET can produce very nice bass and a realistic soundstage too. When I think of a matching system I would also have to include the interaction of the room, which is probably the cause of poor sounding bass in many cases.SET’s wont make bass on poorly designed speakers , with a proper match, SET’s do make bass , very good bass ..!
Well not yet but having seen how this can evolve I understand where you are coming from. So far the commentary has been interesting and the bias for the most part obvious.SET thread descends into Yet Another Ralph Anti SET , Atmasphere Product Placement , Shill Off … What A Shocker … Yawn !
