My pleasure!Dear Ron, many thanks for taking the time to provide such wonderfully detailed and very helpful feedback. Much appreciated. Enjoy your trials with Lara. Happy listening.
Great, welcome to the club!New Pass owner here. Had been using Spectral gear, but problems with the amps and a four-month repair prompted me to look elsewhere. Cannot get new Spectral designs (the new 400SV amps, for eg.,). I had been using MIT cables, specially designed for Spectral. Spectral used only RCA interconnects. Have a long 12 meter run between amp and preamp. A 12 meter interconnect can be a very pricey component. But RCA was not good enough. Changed to balanced cables when my audio dealer found a new pair of 12 meter-long Cardas Clear balanced interconnects in his stock. Amazing. That made a huge impact on SQ. Now with these new cables, (interconnect and matching speaker cables) the sound has opened up in a big way. I matched the amp with a Pass XP32 preamp. That is a good unit, maybe better than my old Spectral 30SV, which was quite good. Sources: Spectral CD (SL4000) + VPI AvengerDirect TT.
HelloGreat, welcome to the club!
Which amp?
Thanks for your reply, Frank. You have a system I would love to hear. If you're ever on tour here in BKK, give me a ring and I'll show you around.To me it's a great combination. The Sonus Faber is the only Sonus Faber speaker I've owned but I've had a lot of speakers over the years. The Sonus Fabers replaced Wilson Alexandria IIs. I had never kept a speaker longer than 4 years since the mid 80s when I started purchasing high end components. I've now had the Sonus Fabers for 13 years and don't plan on letting go of them any time soon. I added the XS preamp and XS phono to go with the XS300s in 2021 and have been extremely content since. I've had Rowland, ARC, Boulder, Sim and a few others in the system but the combination I have now seems to have cured my need to continuously make changes.
Hell yes!! My XA60.8s sounded good of the bat, then went a bit dark, to them 'emerge' after 4 weeks. Right now at 12 weeks+ solid use, they are heavenly. Seriously have no urge to go back to tubes or change them. The sound is very smooth, relaxed yet detailed and fast, which is a remarkable achievement as they rarely go together. Driving the Pure Audio Project 15 Coax, they are ticking over for seriously big dynamics, bass and room filling music. I would recommend these amps to anyone. Don't think as they are 'affordable' they are low-fi, far from it, more like giant killers!My XA60.8s arrived early this week, and they already sound excellent.. I they get any better, probably they'll be dethrowning the PSA BHK600 monoamps.
I have the same amps as well as the XA25. It happens every time they are switched off. It's entirely normal - it's heat dissipation from inside the chassis. Only happens when the amp is hot (on for several hours).A question on Passlabs amps. I have a pair of new 60.8 monoblocks. They sound superb. If they are on for say 6 hours or more, on switch off, the right amp gives out a 'clunk' noise about 30 seconds after power off. Then both are silent. It is a physical clunk, not via the speakers. Sounds like the heatsinks or top plate is moving. Any ideas?
Yes that is what I am doing. Thank you for that I formation. I can confirm the amps are dead silent at the speakers, even if you put your ear right up to the speaker while they are switched on.I used to own the XA 100.5's. Remember, only shut off the front power switch so the main lights go out, but not the rear panel on/off switch. This will extend the life of the capacitors. I believe Robert Harley mentioned it in a review.
No not at all. They have special footers to accommodate stacking them.do the xs monos suffer any sonic consequences if they are stacked on top of each other like they were depicted in their brochures?
