Xs preamp
VPN
369
180
318
Just installed the XS Pre. It's been plugged in for an hour and the XP30 is going back in the box. No need for a/b repeated comparisons. Initial impressions:
Music has more body, frequency extremes more extended, articulate and refined. I can't wait for it to settle in after a couple days...
Hello Christian,
How is your Pass Xs Preamp sounding now compared to XP30?
Thanks,
VPN
ozy
222
40
895
Atlanta ,Ga.
PeterA, the xs amps are coming soon... not sure yet when...
i use siltech cables thruout my system. just added recently the triple-crown i/cs from dac to preamp, and from preamp to amps......
to my ears, the xs pre sounds very tuby and wholesome.
Sammy T
241
26
933
The Pass Labs XS Preamp is truly amazing in all regards , it replaced my 5 year old Ayre KX-R .
MadFloyd
775
1,700
Mass
Sammy T
241
26
933
This you might find interesting, use of the remote control on Pass Labs XS Preamp . Surprising there are no ill effects in sound quality , using the remote to change volume levels. I found this not to be the case with my old Ayre KX-R preamp. Use of the remote , turned on the display added a bit of haze to the music mix. The effect was very noticeable .... remote stayed in the drawer.
MadFloyd
775
1,700
Mass
That IS interesting. So when you used the remote on the KX-R and it caused the display to turn on, did it not turn off a second or so later and with it the haze?
Sammy T
241
26
933
Yes, the haze did fade away after the display turned off. Using the volume controls directly on the Ayre preamp did Not introduce any noticeable haze to the music.
MadFloyd
775
1,700
Mass
Thanks, Sammy. There are a number of manufacturers who claim adding a remote control function degrades the sound. While I'm sure it depends on the exact implementation, this seems to be an example of one that isn't ideal.
Enjoy your XS. It's a fantastic preamp.
MadFloyd
775
1,700
Mass
MadFloyd, how much do you like your XS Phono stage?
A lot. It's like the XP-25 on steroids. Detail is incredible all throughout. Bass is deeper and clearer. Layers of separation for complex music is fantastic. As you would expect for something that costs 3-4x.
That said, I'm selling all my Pass XS gear (I own the XS-150's as well) as I want to try tubes and can't afford to keep everything.
Sammy T
241
26
933
Tubes??.... Ypsilon , preamp, and phono Would be one of my picks . Power amps stick with Pass labs . How much for the XS Phono?
ack
May 6, 2010
6,774
1,198
580
Boston, MA
I want your XS Phono (and your M-Pros; after all, you are getting S7s - a much better speaker Ian, isn't that true)
MadFloyd
775
1,700
Mass
Heh heh. Speaking of Magico, I heard your next speaker this past Saturday, ack - it was VERY impressive.
ack
May 6, 2010
6,774
1,198
580
Boston, MA
Yeah I read your report, thanks for that; it's got everyone's juices flowing. What a great PR for Magico, to host this event - they are thinking out of the box, unlike my other favorite electronics vendor, out in Sunnyvale
analog brother
233
3
don't sell xs'
that would most certainly be a faux pas.
add the tubes and keep it all for mad combos, according to music being played.
can't afford?
sell a spare car, some scotch, or something.
sell magico and get clx or kaiser kawero or alexia, but don't sell pass.
MadFloyd
775
1,700
Mass
don't sell xs'
can't afford?
Probably sage advice about the Pass XS, but can't agree with you on Magico. Mine aren't going anywhere. And as for the Alexia, already been there and done that.
4,702
As you say it depends on the implementation. IMHO adding a step motor with a belt and a controller that is not powered when the volume is not being actuated, as done by manufacturers such as Atmasphere or Ayre, will not affect sound quality.
