I actually have his Tempesta. I built them from a kit, and with Rick's help turned them into an 3-Way active system.
Right on. Nice speakers!
I do not see the use of AirPlay.
Anyway, with the money saved the best feature is to buy an acoustical measurement kit like this one and make a HR DRC filter to be used in HQPlayer convolver:
Now iSEMcon sells EMX-7150 mic for $346
Actually, in the other thread, I proposed a passive system made up of Benchmark DAC/Pre, Benchmark Amp and small Revel speakers paired with Revel subs. Under 10k (just one quick shot; there are many other viable alternatives out there). Have I heard it? Nope. What I know is that these primary components - source, pre, amp and speakers - come from manufacturers whose goals are fidelity to the recording and quality build, who measure and test exhaustively (and whose measurements have been confirmed independently), and who make gear that plays well with others. I have no patience for builders who do otherwise, unless they readily admit that their products operate outside of accepted standards and are very forthcoming about equipment that will/will not pair well with their own (and this is extremely rare). I'll admit that I don't understand why anyone would have patience with such foolishness, though I suppose making eccentric choices, and spending a great bit of time and money finding the eccentric choices that work well enough together, is a hobby in and of itself. But it's certainly not a hobby that interests me as long as there are still great recorded performances I haven't heard. I know my opinion is not popular here, but I believe that choosing a system, unheard, based on the above criteria, is far more likely to get good results than years of audiophile gear shuffling, in search of "synergy."
Tim
Has anyone heard this supposedly incredible $10K system?
MA30 loaded speakers $2999
Folsom amp /vol $2150
Gustard X20 $800
Oppo BDP-105D $1300
Folsom simple power conditioner $1980
Pangea Audio AC 9 MKII Power Cable 4x $400
ZenWave D1 $125
Analysis Plus's Green Digital Oval AES/EBU .5m $149
Ram Electronic HS Canare 4s11 speaker cable 8ft /pair $74
=$9977
The Folsom ones are priced direct order, which may not be offered too long.
I was very tempted to go with cheaper speakers, and a better power conditioner (maybe up to $5k), or the streaming DSD. But I like the Oppo versatility with the Gustard. And I'm sure no one would ever be disappointed.
I know you'd think that. But unless the Gustard is a mistake, you're in for a serious surprise. However no matter what I say I know you won't care. All I can say to that is come visit me, or I'll introduce you to a stereo in MT that'll make you rethink red book. Best I can do.
Here's a thread on the amp as a DIY project, but it's also offered as a complete unit to whomever requests it (with seriously nice parts). The goal was to make an amplifier that within it's power range is truly high end, available to people that couldn't touch such otherwise. It's far exceeded my expectations. Even more amusing when it bested Tyson's Aleph J and F5, I later discovered the volume control I lent him so he could use it wasn't the correct one I thought it was . You may notice that even with a few flaws, Wayne from HTS wanted to listen with it over Clayton Monoblocks or fancy custom tube amps, on the "fun" day, when the Perfect Storm's were reviewed; and it's much better now. That was one hell of a surprise, I thought Ryan would play it on some cheaper speakers and send it back. I hope that's sufficient to your question.
You recommended an nCore. I wouldn't trade my amp for one, EVER. It doesn't have to have opamps, extra stuff in the signal. I refer to classD as class Dead. It's boring. And I don't really understand what makes you think an amp like mine that pairs well with $50k and $20k speakers, makes it "a cool little amp" vs. run of the mill hypex w/fancy opamp.
Perhaps I should choose another DAC? I thought the Gustard was amazing for all performance.
Also the nCore is higher performance than what is used in the BC Black; it's everything else in the Black system that makes it special.
You haven't touched the idea of a power conditioner in this conversation. Frankly I wouldn't even listen to your stereo much because it doesn't have one. I've never liked any stereo without one enough to be content and listen to a lot of music.
i think its 10watts rms but cant certain. no my dac has no volume control, been down that path and did not like it.
I'm not saying your amps are no good, but there's a reason $50000 commercial systems use Hypex Ncore power. I would listen to them before judging them. If you have better technology than Hypex, I'd suggest you start marketing these modules to OEM's, and put Hypex out of business.
I think the DAC is by far the best value I've seen yet. But bypassing the SDM/SRC of the Sabre chip takes things to a new level.
The Bel canto black just uses standard NC1200 amp modules combined with the SMPS1200A700's. The amp I recommended uses the exact same power supply, only with the NC500's. The NC500's pretty much sound identical with the same buffer stages. Only difference is higher current at very low impedances. The buffer Bel Canto uses is very close to the buffer in this amp with the Sparko's.
As far as power conditioner goes, that's another bonus of using SMPS's for the amps. They reject mains interference much better than LPS's. So power conditioning doesn't have as big of an impact. I'd say add conditioning later if you want to do so. The components I've listed are far more critical.
Hypex amplifiers get used due to power requirements and heat. If those are your requirements for in speakers, they're almost the only option. If the speakers were very sensitive, it'd be different. But Hypex stuff is very modular, so it's easy to plug and play. It's not my thing. It's nice, but I don't consider it to be a real contender. The sound is just never right for me. I can drop words to describe it all day because it excels with some so many common words for audiophile equipment, but overall word is boring because I'm not enticed at all to stay in front of it.
My mistake on the BC Black, I guess it is an nCore as well. But just to point out BC has been using classD amps for awhile now, and they've never been real hot sellers.
The best analogy I can give you is that Hypex reminds me of a Skyline GTR. Oh man it's fast, and handles superb. But it's also ugly, and uninteresting to me because I like a standard transmission. It's just worthless to me, the fun was never in knowing my car was fast, but about how it felt to drive. That also is pretty much the exact argument I'm giving you to my choices for a $10k system. I don't have the buzz words to support my position, but I know what I'm going to sit in front of for longer periods of time, no question.
Also, the Hypex SMPS is better than most SMPS's (but what isn't). However it doesn't provide PFC, doesn't filter the other equipment, and doesn't have dampening for capacitive loads on the line. It is not the equivalent of all power conditioning. It has an actually somewhat restrictive CMC because SMPS's have a lot of self noise. It's important to knock down as much common mode noise as possible - which the hypex's/SMPS's small transformer will generate. In fact the noise an SMPS can dump back into the AC is so substantial that requirements are getting stiffer on them for more filtration and PFC in settings where there's a lot of equipment. The Crown XLS amplifier is a good example with a much more robust filtration, and PFC - it's intended to be used around 100x other pieces of equipment.
What if I told you I have a measurement device that is unequaled, and backed up by processing power unlike anything else? More on this in a bit.
"build" Hypex amps? You mean plug in your opamp and quick connectors... They exploded onto the AudioCircle forum awhile back. It was like 'who didn't have one?' Some members still do, others never liked them.
When it comes to SMPS's, you're wrong Blizz. I don't think you understand how they work fundamentally if you're saying what I'm talking about are "non-issues". I really don't want to be rude here, but I don't think you know anything on the subject. What I'm talking about with PFC and filtration for AC mains contamination is a bigger concern now than ever before. Not everything is about whether it makes it to the amplifier. And I assure you the qualities of PF do make it. You've got all these conditions after conditions in order to make an SMPS viable in your opinion; how do you not see those conditions as obstacles that are problematic for audio designers? Also you're forgetting that classD itself is a noise generator, it's not perfect, even when it's very good like with Hypex. That noise isn't necessarily bad but it does have a signature of classD.
You do realize you can use a Hypex regulator with an LPS, right? LPS's are like SMPS's in the regard that the designer can make a very good one, or a run of the mill one. I want to advise you not to make the assumption that all amps should have SMPS's instead of LPS's, and that everyone using an LPS is simply trying to sell you weight. That's very insulting to so many designers that have tried both. Frankly you're saying 90% of the gear on this forum is 'wrong' , or overcharging for a hunk of iron.
Now what I'm about to say I highly suggest you take to heart. Measurements are indicators, not determiners. And my measurement device that I mentioned earlier is the last word, but despite how good it is it's never a guarantee that everyone will love that which measure the best, after all it's my ears so it's just an opinion; and one that says classD is class Dead.
