I have not, I also do the on-the-fly conversion. I may try someday, I'm very happy with it as is. For what it’s worth, if you enjoy your sound that's all that matters in my book.
Berkeley Audio is announcing a new DAC:
From the announcement:
"We could, like many other manufacturers, convert 1-bit DSD to multi-bit within the Alpha DAC Reference Series and show “DSD” in the front panel display. That would be the easiest approach from a marketing perspective. But that would also mean increasing the amount of processing in the DAC during playback which would degrade audio quality, and audio quality is the reason the Alpha Reference Series exists."
MY TAKE ON THIS:
They are basically saying, we don't do true 1-bit DSD, never have and never will."
ANY THOUGHTS?
My Take on this:
They are basically saying, they can't do true 1-bit DSD, never could and never will."
Best Regards,
Jonathan Tinn
Playback Designs
(...) I totally agree. Their marketing should have simply ignored that format.
Perhaps they also wanted to remember us of one more important point of view according to BADA - playing PCM though 1-bit DSD degrades sound quality. After all more than 99% of the digital recordings are PCM. It seems that audio perfectionists should own two DACs ...
1. Any time you make a DSD->PCM conversion, you degrade the sound. Be it within the software or off-line.
Bruce,
you mean audibly when comparing source file DSD (a) with same file transcoded to DXD in memory not to file (realistically I would prefer it to be the highest bit depth the DAW supports internally 32-bit 352.8kHz) and back to DSD for listening as (b)?
So a and b are both DSD.
Cheers
Orb
Bruce,
Did you try listening to PCM 24-176.4 files transcoded to DSD using the Lampzidor DSD DAC?
No I have not. That's something else to try.
I had a little mishap in the OR last week and I'm feeling worse than sh*t, so it may take some time before I'm back to 100%
Yes it is audible. Michael Bishoor has spoken about this several times as well.
When you've got a sec, can you dig up some links (if his comments are published / recorded anywhere?). I'm a big fan of DSD, but I've been hearing this "convert it to PCM and it sounds just the same!" argument a lot lately. It would be nice to hear a different opinion in-depth.
I found this excellent talk about DSD by Andreas Koch which makes similar assertions. Always looking for more info.
I would not necessarily say it sounds the same just because it goes through a PCM stage (or if using ESS 9018 through their format into Hyperstream solution).
A practical way to show that is click on the top right drop down menu on the following studio link and select Test Bench HD audio files.
http://www.2l.no/
All of these are from DXD master files, and there are a few downloads that are transcoded to DSD.
So you can make your own mind up.
However 2L are probably best for PCM releases (where Classic Channel Records are probably better for DSD).
Cheers
Orb
This is not a good test because the DXD files were converted to DSD. With what?
What you need are 2 separate files, each done natively.
Or
A DSD file that has gone through conversions at certain points and see if you can hear the transitions.
