I had both the Ayre KX-R and the XP-30 at the same time for a few weeks.
The XP-30 is no slouch, but the KX-R is the best solid state preamp I have ever heard.
Best in what ways?
Best in what ways?
Very black background, fast articulate bass, super smooth high end with lots of air
is there the possible chance when you auditioned the XP-30 it was a new, unbroken in unit ?
That is exactly how I would describe my XP-30.
I then borrowed the XP-30 and inserted it into my system where it was clearly better than my XP-20. I would love to own one some day, but I have other upgrade priorities at the moment.
I would say - considering solid state the KX-R is the preamplifier is that sounded better in my system and room in the configuration X-Y-Z.
I have no experience with the XP-30, but I have never seen a Pass system wired with Transparent Audio Reference, that I know pretty well. IMHO sometimes simply changing the cables can reverse ones preference. Most of the times I have seen Pass electronics associated with cables that are not so full bodied as the Transparent ones. I own Opus XLR ICs , but in the same way they can make a great sound, in the wrong matching they can kill the system. As usually, my 2 cents IMHO.
I thought the exploration of the pros and cons of multiple components vs. integration was potentially a very interesting, enlightening discussion. Does anyone know of any comprehensive testing/comparisons that have been done? Do separate boxes typically measure with significantly lower noise than very well-engineered integrated units? I know what the conventional wisdom says; logic can challenge that wisdom. What does the data say? Anyone know?
Tim
Tim,
I think most of the time it is a question of separating the power supplies, distance and direction between noise sources and the amplifying circuits. In order to keep the same characteristics you would end with a very large and heavy box, that would be very difficult to assemble, manipulate and service. There is nothing miraculous in separate boxes, just better engineering.
Considering measurements we still have not agreed on the measurements that have correlation with sound quality, so I will skip this one.
That's the conventional wisdom. And we're not talking about any illusive "sound quality" that's subjective or difficult to recognize, we're talking about noise. It is measurable to well below audibility. If one approach is clearly better engineering, that should be very easy to demonstrate. Has anyone done that or do we believe the multi-box solution is better because we've always believed the multi-box solution is better?
Tim
It is fact that keeping the power supply in a separate unit away from the analog gain stages is preferable from a noise standpoint/distortion standpoint than a single box unit containing both.
I'm quite sure there have been manufacturers that have built boxes with internal PS and as an upgrade, offered with external PS.
There is the other side of the coin with designers and equipment that simpler is better.
the multiple box design has not quite been so easy with the XP-25 phono stage from a noise perspective. That took me an age to remove the hum - it is a hum magnet and to me it seems to be a design flaw. Seems to not like large transformers. The two box XONO you could put anywhere and zero noise.
In the end it comes down to the design and the sound the designer is looking for than any given superiority of one over the other.
I had a tape pre in here that had a hum AND picked up RFI.... it had an internal PS. The 2 tape pre's that I had in here with an external PS were dead quiet.
