I am ashamed
izeek
16
7
5
69
Maryland
Audiocrast, an Amazon brand. Surely nothing like the cables a lot of folks here have. Till now, I didn't give them much thought. I bought these because irrationally I liked the looks. Whteher I can see them or not(I can). Cheap chinese, yeah. Does it matter to me? No. 0416211911.jpg
tima
5,865
6,939
1,400
the Upper Midwest
Remember Spirit, gas is petrol over the pond.
Towards the effort of linquistic kinship, "over the pond" , that is, here in America, 'gas' is typically either gasoline (your petrol) or LP, liquid propane, or NG, natural gas. Where there are delivery lines to residential or commercial, many of us use natural gas for cooking versus electricity and one reason for that is it is often less expensive than electricity. LP is sometimes used as fuiel for outdoor grills versus charcoal. So "cooking with gas" is something we indeed do.
We have a phrase in UK when things are going swimmingly..."now things are cooking on gas".
While we don't typically say "swimmingly" (although the phrase is used), "now we're cooking with gas" is not a foreign phrase to us and is used when things are going well. :)
Sorry... things are a bit slow here.
Hear Here
744
460
155
Portsmouth, UK
In view of the poor translation of the Description of this cable and other Audiocrast products, I rather doubt it's an Amazon company. In fact Amazon use the brand name of "Amazon Basics" for their own products. Even those are not made by Amazon but made for Amazon. However they normally describe their own stuff in intelligible English!
Your photo shows a cable that appears to be very flexible, yet reviews often say it’s pretty stiff. How would you describe its flexibility? There’s no description of the cable’s construction, so I’m inclined to stick with the Belden cable I mentioned earlier which seems designed to remove interference, etc. Thanks.
DaveC
3,899
2,143
495
I would not assume that every off-brand on Amazon is giving you a product as-described. Link below shows a power cable that could burn your house down... IMO, you're better off ordering from a brand or store that can be verified as legitimate.
Reactions: Mikem53
izeek
16
7
5
69
Maryland
Actually, this cord is fairly stiff. I had to do some rub work to get them to seat without stress on the connectors.
There is this.
  • Cores' Gauge: 10awg*3
  • Cable Diameter: 17mm(0.67”)
  • Cable Material: OFC
  • Volt/Amp: 125V/15A,Max Input: <5500W
  • Connectors: US plug + IEC320 C13
  • External Covering: braided sleeving
  • Ground connect shielding,shielding it is not solidsoli
and this
1.Three cores inside and 10 AWG per core.
2.Cable diameter: 17mm(0.67”)
3.Cable material: Super Pure Copper Multi Conductor Power Cable.
4.Plug A: P046 red coper US standard plug
5.Plug B: C046 IEC C13 connector solid copper
6.Volt/Amp: 125V/15A Max Input: <5500W
7.Cable external covering: red & black mix braided expandable sleeving.
8.Package: 1 x power cable with US plug
So, maybe I'm wrong in my description. I should've said I bought them on Amazon not from Amazon. rofl.
So far I've not been had any problems. The wire used in mine appear to be thick stranded copper wire looking at it's connections in the plugs. All together seems well-built.
I didn't have interference issues before, don't now.
No hum. No noise.
I hadn't thought of the possibility that they would not be up to snuff.
izeek
16
7
5
69
Maryland
The wire in my cords looks like the cable in the second pic.
Hear Here
744
460
155
Portsmouth, UK
There is this.
and this
No hum. No noise.
Yes I'm sure that cable is fine. It is far too heavy for my liking and more so than it needs be, particularly if handling 240 volts as mine would be. The UK cable of the same description apart from UK plug does not specify the AWG of the cable.
10 AWG is ikely to be far too stiff and (for example) the totally reliable and highly recommend Belden 19364 uses oxygen free 14 AWG cable - surely more than enough for 110 or 240 volt equipment. If you need more than 10 Amps, you shouldn't terminate with an IEC plug, so little point in using 30 Amp capacity cable.
izeek
16
7
5
69
Maryland
10 AWG is relatively stiff. AVcording to its write-up it also is ofc. This certainly overkill for my kit but, hey.
Might be biting off more than I can chew here, but I'm going to offer up that these cables make strong impact in bass strength and detail, mid presence and sweetening of my treble, which on occasion could be bright.
All in my mind, I'm sure.
Mikem53
662
581
105
I purchased one of those cheap “high end” power cables off Amazon, Just out of curiosity, to see if I could see or hear a difference. It was like $30 , it Was thick and looked pretty. had a similar orange connector as the one pictured above.
Upon closer inspection, I could see strands of wire sticking out in all directions from the terminal screw that holds it in place, on both leads. I’d say about a third of the wire wasn’t terminated, just sticking out.
I never did hook it up.
I did try an inexpensive PC from Signal cable that was about 3 times the cost, made in the US and built to order. Much better build quality and peace Of mind that It’s built properly and Safe to use.. Money well spent, IMO.
andromedaaudio
8,496
2,844
1,400
Amsterdam holland
This is my pre amp dac and power amp powercord .
I have more expensive powercords that are connected to my studers and telefunken .
I bought those of the guy who did the revision but more out of symphety then that i actually expect to hear something different / better.
I dont think i ever even bothered to try them on the pre amp, power amp or dac .
But the powercord that came standard with the meitner dac aint nothing special either or the new Ml gear for that matter
I think 15 years ago was the last time i tried expensive cords as i got some expensive cords to try when i bought a new ML amp.
But its not good for my loudspeaker marketing though , that i dont play the expensive cable game , but what the hack
