Hello and good evening to you, gentlemen. Don, I have actually known folks to add such a brace to power poles (Used to work for Duke Energy) to prevent the loosening of connections. You may laugh but I have seen it done. What you will see above ground is a grey metal "thing" that sticks out of the ground that is directly connected to the bottom of the pole itself and goes down into the dirt quite a ways. They also use these to brace poles that have rot or are reaching the end of the usable service period of the pole itself.
.......while it is possible the box works itself loose, I can't imagine that impacting the sound. As far as the electrical service goes I have seen older breakers fail prematurely under light load, and it is possible the connections to the breakers have oxidized over time.
Older breakers often fail under a light load IME. We use machinery that tests the limit of the breakers (without going over the load at all) often. They fail in many houses, often.
One thing that folks may not think of is that the original technician did the job right and tight. On slightly loose or not super tight connections, tiny and various vibrations caused by traffic, earthquakes, transformers, machinery used near the breaker box, lightning, heavy machinery used outside near the proximity of the box, vibrations from low frequencies can over time all wreak havoc to what folks once thought was a solid mechanical connection. These slight vibrations can loosen connections over time. Add in what you had mentioned, oxidation, and you have a bad scenario for decent incoming electrical power. Yeah, it will most likely still run the vacuum, operate the microwave and TV but when it comes to higher-fi reproduction,
these do have the potential to become audible. I had such a thing with a connection on one hot leg and a ground before. After removing the oxidation and re-securing the hot leg, no more grain or unwanted artifacts in the music.
While it may be illegal, whenever I work on anything within the main breaker box, I pull out the meter itself. With the meter gone, no electricity has the potential to shock you in any way, shape or form. This scenario does not change whether you are being fed from and underground or an overhead line. All potential voltage stops at the meter, this leaves you free and clear to work around the breaker box at will with zero potential for any electrical safety issues.....provided you know what it is you are doing once you get into said breaker box.
Please note - This is NOT a recommended way to work on any breaker box. When I am done, I solder the lock back together and nobody would have ever known what I did.....unless they watched me do it.
The only reason I do things this way is because I have yet to find an electrician who actually cares about anything other than code. If I start to talk about oxidation, I immediately get the deer in the headlight look. They don't understand that kind of talk. Their philosophy? If it has within the acceptable range of 120 volts, their job is done. Nothing more for them to do. As an audiophile, that makes me cringe.
Making sure that things are no longer oxidized, that all connections are as tight as possible and that the ENTIRE grounding path is also not oxidized and tight definitely has the potential for better sound. You may not hear something that you never knew was there before. Just food for thought....
Tom
