To all of you, thanks a lot for the provided information, I can now kind of summarize as follows; (applicable to the type of cables I'm currently using)
1) IC cables, shorter is better, however not all ic cables are flexible, so alignment of plugs may become difficult if shorter than 1 mtr.
2) Power cables, minimum length is about 5 feet (1,5 mtr) due to flexibility issues as well. So in other words, in case of flexible cable, shorter than mentioned is still okay.
3) Speaker Cables, shorter is better, as long as left and right have the same length.
4) S/PDIF cables, minimum 1,5 meter.
Resale value will be less in case of very short cable, but we understand the the purchase costs will be less as well. Based on my current set up, using the current rack/table, I'm able to use a lot of short cables (=between 40-60 cm long) so I will consider flexibility as well. It will become a comparison between 40-60 cm flexible cables and a 1-1.2 mtr less flexible cable. Of course, as 40-60 cm short cables will usually be custom made, I can indicate the required plug position, so this can be considered by whoever is making the cables. (even less flexible cables, although I understand that a minimum bending radius needs to be considered)
I'm not so much concerned about possible resale value, but would like to focus on best performance. For Power cables I will not go shorter than 1,2 meter.
(I have never seen -nice- XLR plugs where the cable leaves the plug at 90 degrees relative to the plug, because in such case, it would be possible to indicate plug position, and have 20cm long cables -more like jumpers- when equipment is stacked on top of each other
) Of course, zero resale value, but that is not my objective anyway.
Currently I'm using a lot of 1,2 (4 foot) and 1,5 mtr (5 foot) IC cables, but actually it looks like an unnecessary mess when checking behind the equipment, and seeing all these "overlenght" cables. (besides the fact that there is a lot of money hanging in the air behind my equipment
Note: I do have very easy access behind my equipment.
Again, thumbs up to all of you who have contributed and helped to get me a better understanding on this topic.
