Hi Andreas,
Hi Barry,
the breakthrough was your placement advise you gave to the parttimeaudiophile in another forum.
1/3 of the backwall width between the speakers, listening distance is the same as the distance between the middles of the speakers.
Fourthermore I decoupled the speakers by SSC - pucks (
http://www.dienadel.de/SSC+Pucks+net+point+100+-+Schwarz+-+Absorber-4er-Set,i4.htm )because the Rollerballs does not work for me because of my old wooden floor.
BR
Andreas
Well perhaps we can take it one more step.
A few thoughts:
First, perhaps my wording was not as clear as I thought it was. I do suggest 1/3 the wall width between the speakers and 1/3 the room length behind the front plane of the speakers - and also aiming both speakers toward the center of the wall behind the listening position (all as a starting point). But as to seating distance, my suggestion is to experiment with a range that is approximately 10% *greater* than the distance from left speaker center to right speaker center.
My experience has been that an isosceles triangle will make for greater "focus" than an equilateral triangle. With the listening chair in roughly the position described above, I would play a recording (or two) that is known to have very good clarity and imaging and soundstaging (preferably one made with very few microphones). While listening, lean forward and backward from the listening position, so as to change the distance between your ears and the plane of the speakers. I find this can be much like rotating the focusing lens of a camera past the ideal... you can hear the image go in and out of focus. In most instances, I've found the ideal point of focus to be, as I mentioned, about 10% further from either speaker than the speaker centers are from each other.
As to pucks vs. good roller bearings under speakers, to my ears, pucks (like anything) will *change* the sound but they do not isolate (i.e., do not decouple). The changes they make tend to be random and not consistent, where with proper isolation, I find the differences are *improvements* (not mere changes) and they are consistent and repeatable, across every area of sound I know how to describe.
I'm not sure why the old wooden floor would be a problem. Of course, you can always make a small platform to sit on the floor and on which you could place the roller bearings. Just a thought... Once I heard what they did for speakers, I couldn't imagine ever going another way. (Townshend's wonderful Seismic Speaker Stands accomplish very similar results, albeit at somewhat more cost. They may be a viable alternative for you to consider.)
Most importantly, you are happy with where your system is now, so perhaps there is nothing further to change and it is time to simply sit back and enjoy your music library.
Best regards,
Barry
www.soundkeeperrecordings.com
www.barrydiamentaudio.com
