I still scratch my head at people who review power cords as if they were reviewing a preamp or power amp. They talk about the bass, midrange, and highs the PC has. They talk about the how the PC soundstages. The PC is not a preamp or power amp. It has no gain. Here in the U.S., It’s simply transferring 120v/60 Hz from your wall to your electronics. That’s it. No magic here. Many PCs have oversized IEC connectors and they won’t plug in firmly into your preamp or power amp which leaves a path for RFI and EMI to enter in through the gap. If I have to prop up a PC to try and get it to hang straight into the gear so it doesn’t try and pull itself out of the IEC connector due to its own weight, you can have it.
Couldn't disagree with you more strongly Mark about Power Cords Now, most don't cut the mustard and the cure is often worse than the disease But when you find that cable that works with your gear, it can transform dynamics, low end, etc. You should hear the difference between Silver Circles Vesuvius Mk. 1 and Mk. 2 cables used with their own 5se PLC! It is not subtle at all.
