speaker cable recommendations for Joseph audio speakers
yuhengdu
21
2
108
I have a pair of Joseph Audio Perspectives2 floor standing speakers. I have yet to pick a pair of 8ft speaker cables for it. My budget is around 2k usd, 3k usd max for an used pair. My amp is wells audio innamorata signature. The rest of my set up can be found in my signature.
I cannot use speaker cables that have boxes (like Transparent, MIT, etc) due to space constraint. Now I am using a cheap pair of blue jeans 10 speaker cables. I have not tried many speaker cables before, so when I borrow my friend's taralabs 0.8 speaker cables the other day, I was blown away how it improves my system's overall performance. So I decided that I need a speaker cable upgrade. Thanks for any suggestions.
Verastaar Grand Illusion - the copper foil version - not the silver conductor Signature or Statement version. Worked great with both my hyper resolving Merlin VSM's and the more musical Bache Metro 001's. See reviews at 6 Moons, Positive Feedback, and Dagogo. Look at Audiogn, Ebay, and USA Audiomart for a used pair.
Reactions: yuhengdu
If you are confident you will be buying new cable and believe in auditioning in your own system before making a final decision, the solution is easy. The Cable Company. A multitude of choices with a "borrow , send back if you don't like, try another" business model. They probably have every cable known to man from budget to the extravagant. If you go this route, you cannot get your initial money back but can use as credit towards your next choice(s) and eventually, a final purchase. Have fun.
Reactions: yuhengdu
I have owned Perspective speakers (without the graphene). I currently own Joseph Audio Pearl 3 speakers. You should strongly consider Cardas Audio speaker cables. Joseph Audio uses Cardas wires in your speakers. Also, Jeff Joseph generally shows his speakers with a full Cardas loom, including when he showed the Perspective2s at AXPONA. You should be able to find a pair of used Cardas Clear speaker cables in your budget. They are also relatively easy to resell if you decide to move up to Cardas Clear Beyond (which are worth the price increase IMO--I have owned both Clear and Clear Beyond cables). BTW I used Blue Jeans cables on my Perspectives when I first got them. I can guarantee you will hear a huge positive impact by inserting Cardas Clear speaker cables with your Perspective2s.
Reactions: yuhengdu
Great recommend Al. If I were the OP, I'd certainly try that first.
Reactions: yuhengdu
Blown away by Tara? Sounds like love at first sight.
I have not heard any other brands of speaker cables in my system before so, yeah probably. Are you suggesting me to go for the tara, or look for other options? : )
Exactly! Cables are often system dependent. If you find one that blows you away ,you have hit the jackpot. I always advise you should ate a little then get married. Six weeks maybe.
Wlcome to audiophile land. :D
Reactions: yuhengdu
Thanks. I would love to try things around before setting down on the speaker cable. I like used gears but it is very hard to resell used ones based on how slow they sell in general. Six weeks may be too short to try a few different used cables. Maybe enough if I go for The Cable Company route.
I am using Kimber 12TC with my Pulsar. Sounds natural and smooth.
