Cool.thanks Tang but looks are deceiving. This is the house from the outside.
Maybe you can see if VPI can make you a copper fork and knife to east with! Don't forget to sit on a chair that is isolate by acoustic decoupling devicesIt's a commercial island from Bertos with 4 gas jobs, a French top and 2 induction stoves and two gas ovens. You can tell I like cooking. The Marriot here has the same one. I have a Clearaudio Microwave with LPS and using Argento power cord. Grounded with Tripoint as well of course. If you heat up food with a Stillpoint LP weight on top it tastes better. When I serve I place a DS Audio Ioniser to help remove the static from my Dead Sea salt flakes.
Copper has some anti Covid-19 properties so may be that is a good money maker!Maybe you can see if VPI can make you a copper fork and knife to east with! Don't forget to sit on a chair that is isolate by acoustic decoupling devices
A copper Noblesse might actually look quite nice...I know Howie. I talked to Oliver yesterday about building a copper Noblesse and that way we can KILL too birds with one speaker LMAO.
custom colors are available on all the speakers they just take a little more time to get and cost a few dollars more.A copper Noblesse might actually look quite nice...
It really isn't about the width of the speakers but rather how the speaker launches in the room and the type of drivers. Many speakers for example that use domes have lots of off axis reflections that can be very difficult to overcome in some rooms. Thes devices require significant room treatment to calm downGetting back to the room, I did have some apprehension about the Gobels as they are quite a lot wider than the Stenheims. Luckily they have turned out to be less affected by my room boundaries than I feared. Even less so than the Stenheims given the extra width and hence closer wall distance. May be the lack of two 12 inch rearward facing drivers that the Stenheims had helps?
I don't know Elliot, the Divin's stance is KICKASS! I'm sure that larger width is helping with the bass response. You can tell quite a bit from a speaker's physical shape the Divin's just look right from every angle.It really isn't about the width of the speakers but rather how the speaker launches in the room and the type of drivers. Many speakers for example that use domes have lots of off axis reflections that can be very difficult to overcome in some rooms. Thes devices require significant room treatment to calm down
DavidI don't know Elliot, the Divin's stance is KICKASS! I'm sure that larger width is helping with the bass response. You can tell quite a bit from a speaker's physical shape the Divin's just look right from every angle.
david
Only briefly. I've heard them a number of times but they have never struck me in the same way. More a personal taste thing I guess.Howiebrou, in your speaker search did you consider YG Sonja XV ?
True. I think they appreciate power although I am coming to the realization that many other speakers do regardless of efficiency or load.Also you wouldn't be able to use many tube amps on XV as its pretty power hungry.
He was a pleasant kid and as they say there is no such thing as bad publicity.
Tobias if we are talking apples and apples more power is never a bad thing. I prefer the Noblesse with a large amp whether that is tube or SS is not really the question. It is always about the quality of the electronics. I have heard the speakers with both. I use CH Precison personally and I am a big fan of their gear.
