size of subwoofer drivers vs. size of main speaker drivers
16,222
13,687
2,665
Some of us like to add one or more external subwoofer systems to even large, full-range speakers with 15" woofers (such as XLFs and Neoliths) for low frequency extension down to 20 Hz or below and for enhanced soundstage ambiance. Many of the subwoofers available today solve for small footprints (e.g., JL, Paradigm) with the result that the drivers in the subwoofers are smaller in diameter (10", 12", 13.5") than the woofer cones in the main speakers which are being supplemented.
Other than manufacturers' desire to solve for a small footprint to avoid a large, tall tower subwoofer system, presumably to minimize cost and to maximize "wife acceptance factor," and other than the theoretical advantage that smaller drivers have less inertia than larger drivers, does it make any sense that our subwoofer drivers should be smaller than the woofer drivers in our large, main speakers?
There just seems to be something theoretically inelegant about having 12" cones in the subwoofers supplementing 15" cones in the full-range speakers.
1) If a main speaker has a 15" woofer, wouldn't we want, ideally, the subwoofer also to utilize 15" drivers?
2) If the 15" woofer in a main speaker is in a ported enclosure as part of the main speaker cabinet, is it technically suboptimal or sonically problematic for the subwoofer to be a sealed box? (I know that Wilson and Martin-Logan use ported cabinets for their 15" cones but I have always been a bit skeptical about that, at least from a theoretical point of view.)
DonH50
Jun 22, 2010
3,968
326
1,670
Monument, CO
Disclaimer: I am not a speaker designer. Nor did I stay at a Holiday Inn last night, but I have piddled with this for a while and had a few grad courses long ago in a galax* -- oops, it was this galaxy. ;)
There are many factors that determine the performance of a speaker and size is just one. To use a fairly extreme example, a 15" driver with a small voice coil around a dinky little magnet that has half an inch excursion is likely going to be walloped by a 10" driver using a large voice coil around a huge magnet offering 2" of excursion. Designers have many parameters to vary in optimizing a design to fit a particular market. Small footprint can be addressed in several ways and the compromises (design trades) made yet provide much better performance than a larger driver in your main speakers.
That said, most certainly there are main speakers out there with subwoofer-class performance. The majority of mainstream speakers are not, at least IME/IMO.
One other reason for adding a sub is to smooth room response. That typically means placing the sub where it works best based on physical room dimensions, and that is rarely where the main L/R speakers live. A smaller sub is easier to place and, since it is often closer to the main listening position, may not require a large driver nor as much output.
The phase and frequency response (roll-off) of sealed and ported systems is different. Sealed systems roll of more slowly below their -3 dB point where ported systems roll off fairly quickly below the port tuning frequency. But, the ported systems typically have higher output at and above the port frequency, all else equal. Around the port frequency those systems unoad the driver so the sound can become muddy. This can make integration more a challenge, but unless your room is huge the wavelengths are so long that it only really matters at and around the crossover point. You have to time/phase-align at the crossover anyway since they probably aren't at the same physical place in the room. IME experience the biggest factors in how well mains and sub integrate have more to do with other design choices beyond the sealed/vented debate. Several companies, including Rythmik (my current subs) use servo technology that largely obviates the sonic difference between sealed and ported, at least as far as distortion is concerned. Phase and frequency response differences still exist, natch.
It's complicated...
In the past I would only consider sealed, and preferred a servo design to control ringing and distortion. These days, while I own sealed, there are a lot of good designs sealed and ported, servo and not. It helps that now big amplifiers are common that can better control a sub.
IME/IMO/usual disclaimers apply - Don
LenWhite
424
72
375
Florida
systems.audiogon.com
I believe active subwoofers are designed for one purpose - low frequency response. Using a subwoofer also relieves the amplifier(s) driving the stereo pair from the burden of reproducing deep low frequency response.
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
Adding to Don's good explanation and the same disclaimer of not being a speaker designer, the other variable is power. Subwoofers routinely have 1000 to 2000 watt class D amplifiers optimized for their loads. That power combined with the right driver, can put out incredible amount of bass, compensating for the smaller size of the enclosure and driver. I think it was Bob Carver who originally brought this thinking to the market with unusually small subs at the time. Something that is the norm today.
Then there are tricks that are used in subs that can't be implemented easily in the main speaker. One is the so called "transmission line" subwoofers. I have one that has a tiny little 6 inch speaker in it. You would think it came out of a clock radio. Yet because of the special design of the enclosure, it puts out bass well above main speakers. Danley is one manufacturer of such subs and the bass it puts out is scary. At work, we custom build these kinds of subs and you have not lived until you try to talk over them and your voice gets modulated with the bass being played by them! :eek:
Of course, having all of this and huge drivers helps even more :). But unless you are going for outdoor sound, the techniques are sufficient to power our home listening spaces.
GaryProtein
2,542
31
385
NY
. . . There are many factors that determine the performance of a speaker and size is just one. To use a fairly extreme example, a 15" driver with a small voice coil around a dinky little magnet that has half an inch excursion is likely going to be walloped by a 10" driver using a large voice coil around a huge magnet offering 2" of excursion. Designers have many parameters to vary in optimizing a design to fit a particular market. Small footprint can be addressed in several ways and the compromises (design trades) made yet provide much better performance than a larger driver in your main speakers.
That's what I was going to say.
Rodney Gold
983
11
18
Cape Town South Africa
You need to know what levels of bass you are looking for .. ie what level are you listening at
Do you want thump you in the chest and suck the breath out f you whilst pressurising your ears or are you listening at levels where you can converse..
Pointless spending money on a pair of SVS sb13 ultras if you in the latter category.
A swarm approach with 4 smaller subs vs 2 x big ones is something you can try..apart from delivering the bass and spl , they will also just kill all room bass issue to a huge degree.
http://www.enjoythemusic.com/diy/0812/distributed_bass.htm
and
http://www.theabsolutesound.com/articles/audiokinesis-swarm-subwoofer-system/
The secret with subs is integration ..
4,704
Although I do not remember the details any more, I have a read that an important aspect of subwoofers is the total area of the cones because of the way they couple to the air in the room. The impedance matching between the subwoofer acoustical parmaters and the effective mass of the moving gas was said to be critical.
The article (in french ..., I think it was in Revue du Son ) addressed why the authors felt that a 500 square centimeters cone with 1 cm max excursion could be better than a 250 square centimeters with 2 cm max excursion, even with equal measured distortion (not these numbers, surely).
16,222
13,687
2,665
Don, thank you for the background. I am familiar with transmission line designs, Amir. And I agree with Amir and Don on all counts!
Rodney, I am looking only for linear extension to 16 Hz for two channel music. The more than two subwoofer ("swarm") approach appeals to me. If I get the Neoliths I would probably get four Martin-Logan BalancedForce 212 subwoofers (eight 12" drivers in total). Thank you for the links!
DonH50
Jun 22, 2010
3,968
326
1,670
Monument, CO
microstrip (glad you did not choose "stripline", not sure I could live with that image! :) ),
I have read pro and con articles about that over the years and it was the topic of a chapter or two in my acoustics class back in college. The main counters I recall are that the wavelengths are so large that acoustic coupling differences were not the main issue once you got enough area to do the job (note 500 cm2 is about 12.6 cm radius, or about a 10" diameter cone, if I did the math right). The sub is a point source long-wavelength emitter, a sort of specialized thing. Lower excursion generally leads to lower distortion due to both staying better within the linear range of the voice coil and further away from modulating (flexing) the cone itself.
In any event this is not my area of expertise so I do not know who is right. I'd like to think the weight of evidence I have is that a good 12" driver is fine for most of us, but that is probably because it is all I could afford and would fit in my space. I am sure if I had space (and funds) for a pair of 18" subs in place of my 12" pair I would find a way to argue the other side...
RonR -- Glad I could help, but keep in mind I am no speaker expert. FYI, my pair of little Rythmik F12's (12" sealed subs) is down about 3 dB around 14 Hz and 6 dB around 10 Hz in my small'ish room.
DaveC
3,899
2,143
495
Right, this is why compression drivers are effective when used with a horn, the horn acts as an impedance transformer between the diaphragm and the air. So a driver cone with larger surface area does this more effectively vs a smaller one but ime other factors are more important with subs and it's possible to get good sub performance out of smaller subwoofers. Like most things, implementation is the most important aspect of the design. For woofers, I am a believer that bigger is better because it allows better macrodynamics, for example the impact of a kick-drum is more realistic with a larger woofer vs a smaller one. OTOH, there are examples of speaker with exceptional dynamics that use smaller woofers like the TADs, but they are not inexpensive.
16,222
13,687
2,665
To advocates of the multi-subwoofer, "swarm" approach: So why do we see in the "statement" products of top speaker designers (e.g., Evolution Acoustics MM7, Genesis 1.2 and 2.2, Gryphon Pendragon, Martin-Logan Statement) one-piece subwoofer towers with a large number of drivers in a vertical array rather than two or four drivers in each of four or more subwoofer modules which can be located individually around the listening room?
Is it simply that tall towers are cooler visually for top-of-the-line products and that designers just do not want to deal with the inelegance of multiple smaller subwoofer boxes?
Or do top designers simply disagree with the distributed subwoofer, "swarm" concept and believe that a line source of very low bass is better sonically?
LL21
14,430
2,518
1,448
Great thread, Ron. If okay with you, i'd appreciate piggy backing here to ask a few sub questions as well.
We are remodeling a living/dining room (15x40x11 or 4.5mx12mx3.3m) where the main Wilsons will fire 26 feet down to the listening spot. This is not a place for multiple subs, despite the space, possibly not even 2 subs.
With 1 corner sub, are we going to get a big jump in performance upgrading from our older Velodyne DD18 to a Paradigm Sub2? or even a DD18+? (The Sub 2 cost is about the limit of any speaker-related upgrade...so no Alex 2s or Magico QSub 15s). This will be both listening (classical but also deep house, Hans Zimmer soundtracks, etc) and watching (mainly) action flicks.
16,222
13,687
2,665
Of course, Lloyd.
That is an excellent size room you are working on there!
I do believe that two subs rather than one is valuable. But it is hard to figure out if we are better off with one of those Paradigm subs or with two subs from most other companies for the same money.
Similarly, what would be better, two Thor's Hammers or four of the Paradigms? Madness lies in all directions. : )
LL21
14,430
2,518
1,448
Of course, Lloyd.
Hey Ron, i have heard from many people that Thor's Hammer is in a class by itself, particularly for the Wilsons. Besides cost, there is also the matter of another amp which is both further cost but also further space which is not in the cards here. We are trying as much as possible to have no cables, no visible equipment, just 2 speakers and in a corner 1 sub.
16,222
13,687
2,665
This subwoofer stuff is a conundrum. I am exploring with a subwoofer designer a custom subwoofer tower system with three pairs of dual-opposed 15" driver modules in a vertical array per side (six 15" drivers per side, 12 15" drivers in total) with high wattage amps powering each module. I just wonder, how can two Thor's Hammers (four 15" drivers) be better than that?
I understand. That is a challenge to hide all the cables and the equipment.
ACHiPo
519
309
310
Pleasanton, CA
I'm not sure, but I suspect it's a combination of cool factor, the relatively newness of the swarm concept, and the room integration required.
LL21
14,430
2,518
1,448
...I am exploring with a subwoofer designer a custom subwoofer tower system with three pairs of dual-opposed 15" driver modules in a vertical array per side (six 15" drivers per side, 12 15" drivers in total) with high wattage amps powering each module...
basically 2 vertical stacks of 3 Magico QSubs per stack! ;)
GaryProtein
2,542
31
385
NY
The line array simply sounds really good! It sets the stage at the front of the room, just like real music.
For multichannel sound like in movies, you'll want the multiple sub routine.
Rodney Gold
983
11
18
2 towers is also a swarm of sorts , what with the vertical aspect and 2 of them.
I'm going for 4 or 6x very midrange type $400-500 subs to mess with the swarm thing.. 1 ft cubed stuff with 10" drivers .. 1 ft cubed is easy to scatter about the room, which is the whole point of the swarm thing ..
I dont really need much more or deeper bass, the G1s do palpable and room pressurising 16hz in my room and do low bass at ungodly levels.. The subs Im looking at are around -3db 25hz lowest limit, 100-200w amps
If it doesnt work..I'll flog em on and not lose the farm...
Duke LeJeune
Jul 22, 2013
751
1,216
435
Princeton, Texas
As the room size increases, the room's natural modal behavior improves. One of the arguments for the swarm concept is that it more closely approximates the highly de-correlated low frequency sound field of a much larger room. Statements systems often have the benefit of being located in a very large room, and so generally have less need for what a swarm offers. In other words, and this is somewhat counter-intuitive, the smaller the room, the more subs you should have!
I haven't made a direct comparison between a pair of subwoofer towers and my four-piece Swarm. But one of my customers used to work for a company whose statement system included such towers, and he prefers the Swarm (I'm capitalizing the word here because we're referring to my system that goes by that name, whereas elsewhere I think we're just using the term generically).
Several months ago I built a custom system for a room that was about 50 feet by 30 feet with a 16 foot ceiling. I went with two big subs instead of four small ones. I felt like the improvement from going with four subs would have been small, and meeting our WAF target was critical. They weren't towers, but were rectangles that went up against the side walls.
I believe that the benefit of a tower sub would lie more in its placing woofers in proximity to two opposite room boundaries (floor and ceiling... sort of a vertical swarm effect, if you will), than in its line-source geometry. Because it takes a while for the ear to even detect the presence of bass energy (at least one wavelength) and even longer to detect the pitch of that bass energy (several cycles), I'm not sure an initial line-source launch makes much difference because by the time you hear the bass, the room's effect is dominant.
However if the crossover between mains and towers is north of 80 Hz or so and/or uses a gentle slope, it starts to make sense to match up the radiation patterns of mains and subs, and to keep them near one another. Radiation pattern mis-match is imo the major weak point of most hybrid electrostats, for example.
