About two weeks ago I received the new Taralabs grandmaster evolution (6 ft) loudspeaker cable and Taralabs grandmaster evolution (1,5m) ic cable. These new top of the line cables are not yet officially launched by Taralabs. However the word spread rapidly that the Grandmaster evolution cables are something extraordinary and they can be ordered, although the availability is restricted (partly because it takes quite some time to produce them). Being a music lover and audiophile for more than thirty years I have learned the hard way that a lot so-called break through products do not live up to the expectations. And although I was a little sceptical that the new grandmaster evolution would outclass my taralabs omega gold and zero gold cables, after talking several times to Matthew Bond and Devon Scott I took the jump. Boy, what am I glad that I did!
Having listened to them for about 50 hours I can say the following: the grandmaster evolution cables are by far the best loudspeaker and ic cables I have ever heard. These cables sound on the one hand very calm/serene but are on the other hand the most dynamic cables I have ever experienced. Furthermore they are very refined (velvet) sounding with a huge soundstage (deep as well as wide) but at the same time with a focus that exceeds easily all other cables that I am familiar with. Probably as a consequence of the great extension of the grandmaster evolution cables they also give you the impression that the soundstage is larger in height without making the players and instruments larger than they are. For example, the distance in height between various players in a large orchestra can be noted easily. Talking about an inky black background and transparency: the grandmaster evolution excells in this regard.
BTW, I connected the (double box) Taralabs grounding device to my Tripoint audio Troy signature se grounding device and noticed that the haze on some vocals was (nearly completely) gone. Spooky!
If I am informed correctly, the new Taralabs evolution line (situated directly below the top of the line grandmaster evolution cables) is right now being tested and reviewed by one of the leading audio reviewers. So if you find my great enthusiam hard to swallow, wait for this review and find out if there are oher people who are as impressed as I am.
Top notch products never come cheap and the same applies to the Taralabs grandmaster evolution line. So probably some WBF readers will jump on the issue of pricing and will be very criticall. I am not going to react to this and can only advise the following: try to give the grandmaster evolution cables a serious listen. They are phenomenal imho.
For those who are interested I include some info from the Taralabs website. Happy listening to eveybody.
"The Grandmaster Evolution Interconnect with “Dual Mono-block” HFX Floating Ground Station System
The Grandmaster Evolution Series from TARA Labs is truly beyond belief. It is quite simply the new watershed in the art and science of audio cable design. The Evolution Series is in a class of its own, beyond all other audio cable products in the history of the audio industry worldwide.
The Grandmaster Evolution Interconnect uses the same multi-lumen air-tube concept invented by TARA Labs as used in the ZERO Interconnects and the AIR Series Interconnects originally developed in 1986. However, the Evolution Interconnect is remarkably flexible.
The Evolution Interconnect uses the same displaced and Floating Shield design together with a new Dual Mono-Block HFX Ground system with greater absorption of RF/EMI and a vanishingly low background noise.
Incredibly, the new Grandmaster Evolution Interconnect boasts a remarkably low capacitance figure of just 2 pF per foot. This means that the new Evolution has a High Frequency bandwidth that is more than 300% greater than any other high-end cable in the world.
• The most advanced air-tube technology and design
• All new proprietary “dual mono-block” floating ground station (HFX) and floating shield system
• Controlled spacing of conductor to conductor geometry, produces record low interconnect capacitance of a mere 2 pf (pico farads)
• Additionally the conductor to shield capacitance is remarkably low so the EMI/RFI coupling from the shield to conductors is negated
• The outer shield is expanded and spaced away from the conductors to such a degree that the background noise is at an all-time low
• Two layers of anti-corrosion coated SAOF-8N copper shield
• Compared to the Zero Evolution, The Grandmaster Evolution has a larger, more complex system of Teflon and Aero-PE filaments that ensure a complete air dielectric system.
• The most revealing and lifelike presentation possible
• Compared to the Zero Evolution, The Grandmaster Evolution has a high-frequency bandwidth that is 50% greater, with a stunning low level of background noise contrasted with more image outlines and fine detail
• Revolutionary liquid micro-film (LMF) dielectric ensures a linear transfer of low-level ambient and spatial information
The Grandmaster Evolution Speaker Cable
The new Evolution speaker cable is a stunning achievement, boasting the greatest current-carrying capability of any speaker cable in the world, together with the High Frequency extension and linearity of a 32-gauge conductor. The Evolution Speaker Cable is an all air-dielectric design with 288 Rectangular Solid Core ® conductors per channel.
Importantly, the gauge size for each channel is far greater than any speaker cable ever made or ever conceived in history. The gauge size is not 10, or 6, or 4, or even 0. The gage size for an Evolution Speaker Cable is 000, that’s an area of 85 square millimeters per channel.
• BSM (with 1/4”or 5/16” Spades or Bananas)
• Gauge size is 000 = an area of 85 Square mm per channel
• SA-OF8N® copper.
• Each channel comprised of 288 Rectangular Solid Core ® conductors per channel
• Aero-PE® GMI™ dielectric.
• Separate positive and negative conductor run for each channel.
• Helixed Rectangular Solid Core® conductors and air-tube technology
• Spectacular power and clarity. Absolutely neutral and coherent.
• Superb resolution of micro-detail and ambient information.
• Incredible dynamic contrasts & vivid imagery
• Holographic soundstage & superb resolution of micro-details
• Excellent imaging & absolute coherent and neutral
• Holographic soundstage & superb resolution of micro-details".
Grandmaster Evolution Interconnect, 1 meter - Retail $28,000.00
Grandmaster Evolution Speaker cable, 8ft/2.4m – Retail $42,000.00
• SA-OF8N® copper.
