Why not just spot-check, and then focus on those that look suspgicious?
there is no excuse for digital clipping. Seeing some of the recent graphs in this thread are just sickening. there is an awakening taking place and thats good.
I'm not sure what you mean? This has been going on for over a decade, and while overall I think newer releases overall may be a little better in this regard than those from a couple of years ago, it's probably not from any kind of "awakening", it's more likely that even the most tin-eared listeners realized that music with a dynamic range of only 10-15 dB just isn't very pleasant to listen to
Unfortunately there are quite a few "true hi-res" (in the sense of genuine 24/96 or even 24/192) recordings offered for sale which are still compressed and/or peak limited all to hell. There might be increased awareness of this, but I personally haven't noticed much change in the marketplace offerings. I hope I'm wrong.
Compression / peak limiting is at least an "artistic choice" by someone - artist, engineer, producer, label executive - while I would hesitate calling upsampling or zero-padding an artistic choice![]()
But Tom's post specifically mentioned "digital clipping", not fake hi-res.
Right. And it was to that part that I referred to with "the loudness war has been going on for at least 20 years, and I don't see that getting much better".
Which was the whole point of my post; Tom apparently thinks there is increased awareness (and therefore improvement), whereas I'm not so sure...
Just to add a modern example of a "lite" genre recording.
High rez version of Diana Krall's Glad Rag Doll has most of its spectra content up to 1khz between -10dBFS and -30dBFS, this is from an artist who is recognised to having great talent and fits closer to the audiophile niche.
I did emphasise 0dBFS, but should be noted my concern in that post also for up to -20dBFS, which shows some performance considerations for certain DAC architectures and implementation.
Cheers
Orb
Bruce,
When you say 24 bit compressed versions of the original 16 bit CD can still be "hi-rez", it's distinction without a difference.
The whole point of offering 24 bit files is that they allow for substantially greater dynamic range than 16 bit files. When anyone offers a 24 bit file claiming "hi-rez" with 1/2 the dynamic range of the original 16 bit CD, that's ugly.
Why do you want to do another conversion? Every change degrades the sound.
Well, the loudness war has been going on for at least 20 years, and I don't see that getting much better, but hi-res downloads are a fairly recent thing, and along with that there has been the temptation to offer quick-and-dirty "hi-res" recordings that are made by up/resampling and zero-padding CD/redbook material, or in best case, resampling sacd material.
Nonsense.
*So much* nonsense on this thread, it's mind boggling.
Everytime you do a sample rate conversion it degrades the sound. This is a fact.
1) you wrote *every change* degrades the sound. That's nonsense.
2) and more fundamentally, you need to define 'degrade'. If I sample at 192 kHz and carefully filter out the content above 44 kHz later (i.e., to resample at 88kHz) , i've removed content that no one will ever hear in the first place. That's decreasing the bandwidth but is it 'degrading' the *sound*'?
