Weiss Medea vs. Medea+
AudioExplorations
653
7
928
I don't suspect I will get a response right away, but hopefull at some point someone will come across this thread and be able to provide some perspective :).
I currently own a Weiss Medea DAC, and am considering having it upgraded to the 2011 Medea+ spec which will replace the 2000 AD1955 DAC chip with a 2011 32bit ESS9018 and replace the entire analogue output stage with Weiss's latest and greatest SOTA OP1-BP discrete opamp based output stage.
Further info: http://designwsound.com/dwsblog/2011/12/medeaop1-bp-board/
Looks great on paper but I am wondering if anyone can compare the differences in sound. I have tried getting my hands on a Medea+ unit but have been unable to do so.
Any impressions are highly appreciated!
Joost, there are not many posts/reviews out there on the Medea Plus. Keith from Purite Audio in the UK who regularly auditions and sells the top DACs in the world rates it as the best he has heard...better than the StahlTek which was a previous favorite of his. That's the only data point I can provide.
Thanks, yes I have seen some of his posts. I have also read various accounts on the audiogon forums of the Medea+ being a significant step up and considered by some there to outclass the Scarlatti by some margin.
I will soon be able to answer my own question as I have just placed an order on an ex-demo unit, I will report back on my findings.
Hi Joost,
The Medea+ should be a great performer. Please let us know how it works out.
I understand Weiss makes very good stuff, but this is the company that, a couple of years ago, took a DAC from the pro line, put a nice faceplate on it, marked it up by $3,000 and sold it under the label "Weiss High End." I think they called it the Minerva.
The wise consumer would take a very close look at Weiss Professional products before pulling the trigger on any Weiss High End items. Caveat Emptor.
Tim
Yes that is right (I used to own the DAC2). The DAC1mk2 is the pro version of the Medea. Daniel Weiss is very transparent about this. Does it make Weiss High End expensive or Weiss Pro cheap? With pro gear you don't get dealer support; home demo's, installation, after sales service, etc, it is typically sold through b2b channels. I doubt that Weiss high end has more markup then other high end brands like dCs, esoteric, etc. So the way I guess to look at it is that the pro gear is a terrific bargain should you not need the service or mind those aesthetics in your hifi rack.
What is the pro version of the Medea Plus? The DAC1mk2 doesn't appear to have the "Plus" upgrade. Thanks.
Weiss does offer the new DAC chip/analogue board upgrade on the DAC1mk2 also, I confirmed this with Daniel. He also mentioned a retrofittable USB input option will become available for both units which is the same chipset as the DAC202U enabling compatibility with non-firewire music servers such as the Aurender and the SoTM. If you have the financial means you should definitely audition this DAC, it is an absolute gem and completely under-hyped as it arguably bests every other DAC on the market today, particularly in the context of a computer/MAC based and power-amp-direct setup.
