I have long been of the opinion that noise is the great overlooked element in audio production - the focus tends to be on the signal itself & distortions, accuracy, etc. Less, maybe even very little consideration is given to sea of noise in which the signals are immersed & what affects this sea might have on the perceived sound. If it's not directly perceived then it's not often considered. But I've been of the opinion for a long time now that noise which isn't directly perceived can have a significant bearing on our auditory perception - CM noise & it's affects, for instance.
A recent paper published (Oct 2014) that begins to tie together some disparate strands of information about noise that I have held onto. The summary for this paper is : "Barely perceptible low-frequency signals nevertheless activate measurable responses in our auditory circuits. Neurobiologists have now characterized the remarkable impact of low-frequency sounds on the inner ear"
"The human auditory system appears to be poorly adapted to the perception of low-frequency sound waves, as hearing thresholds become markedly higher for frequencies lower than about 250 Hz. Yet sensory cells do react to pressure waves with frequencies below 100 Hz, as revealed by the fact that such signals actually evoke detectable micromechanical responses in nerve cells in the inner ear"
""It turns out that low-frequency sounds have a clearly definable modulatory influence on spontaneous otoacoustic emissions," says Drexl. Following exposure to the 30-Hz signal for 90 seconds, the subjects' SOAEs exhibited slow oscillations in frequency and level, which persisted for up to 120 seconds. "Strikingly, the effect of the low-frequency stimulus on the cochlea persists for longer than the duration of the stimulus itself," Drexl points out. Further experiments will probe the possibility that this phenomenon may be linked to noise-induced auditory damage, one of the most common causes of hearing impairment in industrialized countries."
So apart from the implications for industrial workers & those living near to a wind turbine, I believe it has implications for audio reproduction. I know from my own & others experience that reducing noise leads to a significant perceptual improvement & I'm not talking about noise that can be heard. The best example I can give is reducing or eliminating common mode noise (usually from a ground loop) results in a benefits across the sound stage - better separation of instruments, better placement, a more 3D soundstage, more dynamics - a generally more realistic illusion (if that's not an oxymoron
The information about noise that I have considered significant & held onto:
- Jocko (an RF & audio clock expert) has consistently claimed that close-in phase noise was the most significant aspect in clocks for auditory perception
- a number of people, including Opus111 (who used to post here & goes under Abraxalito on DIYAudio) have reported the perceptual improvements in using a huge over-capacitance at the supply pins of audio chips (both digital & analogue). We are talking about 10,000 more than the usual 0.1uF bypass cap specified in datasheets for this pins.
- He also premised that noise modulation was the big issue with modern D-S DAC chips
- In my own experiments, although not targeting LF noise directly, I have found that reduction in noise sources have greatly enhanced auditory perception.
I have agreed with Opus's opinion that some re-evaluation of our perception influence of noise floors was needed & overdue.
This new research helps to bring together these strands & focus attention on what may be a crucial factor in our auditory perception. BTW, I saw this recently which gives an insight into the one role of noise in our auditory perception - Comodulation Masking release
Any thoughts?
Any thoughts?
