Turntable options to chose from
shaby
4
45
Hi,
Nice to find this forum.
I searching for a turntable from 70's - beginning 80's And was found these:
TECHNICS SL-Q300
Lenco L331
Both sound the same...I dont have A professional ear in order to find the these small differences.
Even if you did not listened to them, I hope you'll able to give your answer based on knowledge.
Thank you!
Hi,
Thanks for your response.
The technics is not relevant anymore.
How is the Lenco 331 OR 133?
Thanks
If I remember correctly, the luxman pd121 was a nice sounding and really well made turntable my late father had for a few years.
Reactions: shaby
If you would need to chose between:
> TECHNICS SL-221
> TECHNICS SL-B3
Which one is better?
Thanks
They are basically the same table. The B was made slightly different so that stores could say the “we’ll beat any price” slogan. But since it was a different model number they didn’t have to. Also it came with a cheap cartridge that some stores would charge extra for and make a little extra money.
