Tubes for Hovland
Pierre
45
Denmark
Hello
I'm corrently using NOS Mullard ecc83 and one NOS tripple mica sylvania 12at7.
These tubes are hard to get and werry expencive, so i'm looking for new tubes.
I acctuly like the sylvania werry mutch and would like to find one more. But the mullards are up to change.
But i dont know witch i shall look for. I would like a werry dynamic tube, that Plays Music.
If i would change the sylvania, can you recomend one?
Pierre
Hi Pierre,
I can very safely recommend the Valvo 7308, Navy Amperex and Mullard CV2492 in your 6922/6dj8 positions. For 12at7 I've not tried many. Once I tried Tele 801s', I stayed there.
Hello
Pierre
As a relatively inexpensive solution try a Mullard CV4024 for the 12AT7.
Hello
Pierre
If you want a dynamic tube, you don't want that Mullard ECC83. Warm and cozy yes, dynamic no. I would try to find the following: Siemens ECC83, Raytheon blackplate 12ax7, Matshushita tilted getter, RCA blackplate, Tung Sol square getter, Amperex I65. If you can use them, 5751 are a great substitute. Can't help with the 12at7 as I don't use them.
Good luck.
