Does everyone with tube gear own a tube tester to check for bad tubes?
If so, what tube tester are you using?
But Greg, that's a digital clock, not a tube tester! (unless you're testing those numerical nixi tubes ;--)) I do have a Hickok 6000A which is a nice reliable tranconductance tester (doesn't test tubes for plate current, however.) If I were going to spend over $1000 on a tube tester, I would definitely buy a new digital Amplitrex http://www.amplitrex.com/index.html They're $2500 but totally accurate, can measure any tube at full operational power, and they're a snap to use because all the tube data is loaded in memory, and easily updated. When you think that (what I consider) the next best thing, a used Hickok 539C, go for $1500 and up on eBay and still need to be refurbed and calibrated, the new Amplitrex equipment starts to look not so bad -- in fact many if not most of the online tube sellers are switching over to the Amplitrex units. The fact that there's a waiting list for them speaks for itself.
Sam, It DID find the shorts that other testers failed to show.
Charles,I like to think of a tube tester as more of a go/no go device. Most do a good job of detecting shorts but you have to be careful in interpreting the results of a "quality test"; i.e. a "questionable" tube may work perfectly well - or be unworkable in a particular application.
And has been pointed out, most testers check the "gain" at only one point on the curve - which could be totally different from the circuit you are using it in. You can "match" tubes but only at that ?? operating point.
I use my Hickok 539B to "grade" tubes - from OK through maybe "better" and mark the transconductance on the side with a magic marker. Then play with them in a particular application to find which "sounds" best.
For preamp front-ends where low noise in important - most testers don't test for this. I think that the Hickoks and some other brands have some kind of noise test capability, but have never checked it out to see if the "measurement" correlates with actual perceived noise levels. Again I use my ears for this.
BTW, I always "clean" the tube pins with Cramolin and before trying to remove any excess, I put the tube back in the socket and circle it around a bit (or pull it up and down a few times) to "clean" both the tube pin and the socket. It really quiets down the tube/socket connection/interaction.
Charles
Charles
Charles,
What is Cramolin and where do I get it?
