Haha
xSam-You obviously don't read me enough. I'm crammed full of gems-or crammed full of something.
Now that my Technics SP-10 MKII project is finally completed, I'm using an SME 312S tonearm. My VPI TNT/ET-2 combo are now collecting dust. I have been a long time fan/owner of the ET-2 and I do find it to be a remarkable tonearm although it is a pain to set up correctly and requires maintenance to keep it running correctly. The one thing that I never cared for with the ET-2 is that you don't have a true ground and hum is always an issue that has to be dealt with.
HI mep,
Well, any tone arm needs to be properly grounded to eliminate hum. I've not found it to be more difficult with the ET than any other arm. That is to say, I don't think it is a problem.
As for maintenance, I have found that there is none except to relevel the arm perodically. This is simply the nature of a frictionless bearing being mounted on a spring suspended turntable. The springs do sag, very slightly, over time. Because of the lack of friction, the arm will detect the change, small as it is. There is no way around the issue if one wants a suspended turntable. If you want to call this maintenance, OK. But the releveling procedure is very simple and takes little time. So, I think you are splitting hairs. It is something to be aware of.
Other than that, I've had no problems for over 20 years. The air supply needs to be clean meaning well filtered for both particulate matter and moisture.
Set up is more complicated than a pivoted arm but it only needs to be done once. After that, releveling is the only set up issue and its a simple one.
Certainly none of these things, no matter how you want to label them, tempts me in any way to change to pivoted tone arm. These things you bring up are notheing compared to the issues that pivoted arms have with their compromized geometry errors. Remember, the basic job for a tone arm is to provide the best possible home for the cartridge and that includes, in a very large measure, the geometrical relationships between the stylus and the groove. Only if you get this right can the cartridge perform to its best. This can never be done with a pivoted arm.
Sparky
HI,
I Googled Durand tonearms looking for information. I found very little. It seems they are very proud of their azimuth adjustment. But not much more information. How did you guy's make your decision?
Sparky
HI Miles,
That helped. But I still don't see where the type of bearings are defined. Unipivot? Don't think so. Gimbals? Yes, I think so. Why its not talked about is a mystery.
Nice looking arm.
Sparky
Myles is correct, the Talea is a unipivot design.
More than any tonearm I have ever heard, the Talea optimizes the performance of the remainder of the analog chain. I've heard the arm with multiple cartridges including the Dynavector XV1-s, Clearaudio Da Vinci, Benz LPS, Lyra, and Ortofon A90 on multiple turntables including Galibier, The Beat, Technics SP Mk III and Garrard.
The Talea consistently allows the system to 'relax'. The noise floor is lower, revealing greater harmonic detail. Frequency and dynamic bandwidth are more extended and there is a density of information that is unsurpassed in my experience. It is my theory that the Talea filters less of the data relative to other tonearms and also allows the cartridge to function optimally. The effect is apparent across all musical generes. The music just flows, allowing the listener to more readily achieve the 'suspension of disbelief'.
