Hello. what are the materials of the arm board from TechDAS made of? I got one for the SME with my 5P and it seems to be aluminium?The shown tone arm base is the original AF3 / AF3P type with the center fitting,
All AF5 and AF5P were using the the side pinch bolt method.
Both tonearmbase designs do fit all AF 3 and AF5 turntables.
In Germany the retail price of the two designs is different.
side pinch bolt (same as the former Micro Seiki design) is much cheaper.
yes, it is aluminium.Hello. what are the materials of the arm board from TechDAS made of? I got one for the SME with my 5P and it seems to be aluminium?
thank you for your tip! Just wondering which arm base should i get if i am looking at fitting the 4point 11 to my AF5?yes, it is aluminium.
If you prefer Gun Metal, you can use the old Micro Seiki AX "G" Versions, which will fit AF3 and AF5
The Linn / Kuzma / Jelco standard was not yet established / popular in the times of Micro Seiki, so no dedicated base does exist.thank you for your tip! Just wondering which arm base should i get if i am looking at fitting the 4point 11 to my AF5?
Or anyone have the drawing of the setting out of the 4 pillars of the AF3 / 5
I am very keen to get info about the setting out. All i need is the distance between the spindle and the circular column support on the Airforce. That case, i can just draw the part out and CNC it out.The Linn / Kuzma / Jelco standard was not yet established / popular in the times of Micro Seiki, so no dedicated base does exist.
In italy a company is producing matching bases, you may ask them for help:
MICRO SEIKI TONEARM BASES
Unique in the world We are proud to present a complete set of tonearms bases dedicated to the turntable Micro Seiki of the RX series, SX DDX, DQX But we did not stop the reproduction of the original, we have also created some models that were...www.audiogears.it
or just order from TechDAS
