I'm a little unsure of what you're referring to here, Roger. In the "correct" view of such things, noise is a relatively constant level of unwanted added signal in the audio, and distortion is variable and dependent upon the source signal, can be broken down into linear, which is frequency and phase response, relatively benign, though some will vigorously disagree; and non-linear, which is harmonic and intermodulation distortion, the nasty stuff in my book.
I've a feeling that you're talking of low level, non-linear distortion when you say system noise here; am I correct?
Frank
There has been much discussion about distortion,sound stage, transparency,room acoustics,but not much about noise. I wanted to start a thread about noise and how it effects the reproduction of sound."In common use, the word noise means any unwanted sound. In both analog and digital electronics, noise is random unwanted perturbation to a wanted signal."
Rogerin high end systems than the distortion present in those systems .
True or false?
Roger
In system, less noise of cause is better than more noise but depend how to reduce those noise, if in adding heavy feed back of amp to reduce, you will have quiet sound but also less of live, so it will up to your own favor, for me I will take no feed back to have more live feeling and transparency ( my system is all tubes and lot of transformers so can't to compare to those heavy feed back transistor amp for noise)
tony ma
RogerHi Tony,
In my experience tube and SS amplifiers can produce great clarity,speed,and transparency. I have found a excellent grounding scheme can effect clarity,speed and transparency. Is this noise related? I think so.
Roger
Proper grounding is one of the way to improve noise and transparency etc, without any to give up at the same time, but will not have same effect degree in all systems, some can have bigger return but some don't, the only thing that we can do is try, and find out the best of for our own system may not suite for others, try and try and compare also with fun too
tony ma
Roger
I put all my interest in R2R now, but in long time ago I made a lot cables include tonearm interconnect and speaker, different materials and constructions etc, finally found out the best one for myself is 4N silver with a power shielding, on and off the power shielding can have emotionally and detail in different but can find any change in noise ( I can't find any noise from cable)
tony ma
Of course we really would have to consider how much of the noise and distortion is in the media and recording vs how much is in the "system" to answer the deeper question, but this one? In absolute terms? There is no contest. If I could remove all distortion, ie; a trumpet sounds exactly like a trumpet, Dianna Krall sounds like she's singing in my room, vs keep all the distortions and eliminate the noise floor of a high end system? Take the distortion; I'll keep the noise. There's not a concert venue in the world that doesn't have a higher noise floor than any high-end system that uses those words to describe performance. I think maybe you didn't ask the question really wanted to ask. Or I just misunderstood you.
Tim
Not all high end systems are of a low enough distortion to produce a faithful trumpet sound?
No high end system can produce a faithful trumpet sound. If you think this is not so, you need to get in a room with a trumpet.
Tim
+1
But then again, most audiophiles would call a real trumpet (especially with a Harmon mute) "ear bleeding bright" and prefer the dulled, high-end-approved version. That's just my own personal experience and opinion, and has no basis in measurement or fact.
My head is exploding.
Tim
