Studer A810 Issues After Battery Replacement
kfalls
Active Member
Jun 24, 2015
34
I'm a Noob. I'm working on an A810 after replacing the battery. All the controls seem to work, but I'm getting no output on either the monitor, or headphone jacks. I've verified the monitor is working in another A810 and have tried listening to an inputted source. All I hear is a very faint sound from the monitor headphone jack with volume as high as it will go. I've never had to set the soft switches except for level adjust and HF adjust. The unit was down for some time, so I understand the soft setting are gone. Could no sound result from this? What all should I check. Thanks in advance for any help.
Ken
Check for the correct setting for DIP switches JS0-JS19, JS1-JS8 on peripheral control, and those on line amps.
yjwu
It seems I have more than one issue. Occasionally while troubleshooting the audio issue, I hear a definitely click the and tensioners release and I receive error messages. Sometimes EEE13, EEE12, EEE02. The only solution is to reseat the MPU, Tape Deck Controller and Periphery Controller cards. It's intermittent, so difficult to trace. It could be a backplane issue, possibly a cracked run which displays with vibration or heat.
You didn't say if the audio was working correctly BEFORE replacing the battery. Same with the main audio output. If there were no problems prior to replacing the battery then I'd look for some cabling/connections that could have come undone during your repair. If it wasn't working beforehand, then I'd suggest checking the +/-15volts that go to each audio card. Got two 812's a few months back and had various bad/leaky capacitors which affected various operating modes. Per Ki Chioi's suggestion; ended up replacing ALL the on-card electrolytic and tantalum caps, and the problems went away.
Also check the cabling/connections to the VU overbridge (if you have one) - something may have come loose there.
Charles
Charles is correct. You should check +/- 15VDC especially when you have error message reported - all related to audio.
One of the first thing I would do with any A810 even with younger SN's greater than 5000 is to pull out the cards, remove the basis board from the back, replace all 470uF and 1000uF axial caps regardless. Even the blue Philips caps can go poof all of sudden and the dreaded yellow Frako caps have 100% failure rate.
The caps in the power regulator (Studer calls is stabilizer) board should be next for replacement.
Then, any machines with audio related issue, I would also suggest you remove the tape headblock and get to the repro head preamplifier board. There are two electrolytic caps for +/-15VDC supply for the opamp that need replacing.
Some of the logic problem even after all the caps replaced on basis board could be caused by a filter cap in the operating LED (LCD) panel for +5VDC. It should be replaced as well.
There are many other electrolytic caps needing replacements in cards but that's another story.
In addition, replacing the battery on the all Studer MPU card can go smoothly but after you pulled the old battery, you should examine the areas around the battery for any battery leaks that can corrode way the circuit traces. If the green stuff is anywhere on the chip socket, you must pull the socket out and examine the circuit traces and replace the chip socket(s). I have had the leaked battery chemical that had corroded the chip socket pins so badly, it dissolved metal pins completely away.
