Revox B77 Logic Problem
kfalls
Active Member
Jun 24, 2015
34
Hi All,
I'm currently working on a Revox B77. It has a logic issue where the function buttons are not doing anything. All voltages and fuses are good and capstan is currently turning. My problem is the Tape Drive Control schematic I have has a different IC4 than what is on the board. The chip I have is an LS7402 and not the SC10429 24-pin shown on the schematic. I figure this is an earlier version without the tri-state chip. I've looked online, but all have the 24-pin chips. I've checked the label and I definitely have a B77, but certain it's not a MKII. I'm sure someone here can provide an answer.
Ken
Is the regulated power supply on the tape drive control board working? Check for 5V on the emitter of Q18 (collector should be ~20 VDC)
I noticed this circuit earlier when checking PS voltages and noticing it wasn't supplied by the power supply. I didn't see +5V on the emitter, so assumed it was open. Q18 and D9 (5.6V Zener) provide +5V for the logic. Without your schematic I wouldn't have determined no signals were getting through the logic. Thanks again for the help.
