After several years of producing award winning products, Purity Audio Design has officially released all new Series 2 linestage products for 2013.
New for 2013 is a newly designed circuit that is optimized for both the 6SN7 and 12AU7 tubes. All models come equipped with an octal socket for use of the 6SN7 with adapters to run 12AU7 tube types. All models from the Basis Two and higher come standard with Sophia Electric 6SN7 tubes. All models except for the entry level Basis mk2 utilize transformer coupling at both the inputs and outputs with transformers custom designed and manufactured for Purity by Electra-Print. Both XLR balanced and RCA single ended connections utilize transformer coupling.
New all aluminum chassis are now standard for all models.
The Basis mk2 is still leading the way in price/performance.
New to the lineup is the Basis Two which takes over where the original Reference left off. A new all aluminum chassis designs allows us to offer you this model far under the price of the original Reference.
The multiple award winning Reference had been enhanced to offer even more for your money. The Reference now offers you everything found in the Statement Series but in a single chassis with a single power supply. The Reference moves up to the same autoformer attenuators and Clarity MR capacitors originally only found in the upper end models. By using the same aluminum chassis as the Basis Two above, we are able to offer you a much higher level of performance at a more attractive price.
The upper end dual mono Statement and Ultra Series are now housed in thick aluminum enclosures.
Purity Audio Design ships world wide to any location that does not have an authorized dealer.
http://www.purityaudiodesign.com
